Passenger side blinker
Old Apr 28, 2008 | 01:26 PM
IXLR894Z28's Avatar
My passenger side blinker keeps blowing the bulb after about 2 days or so. When I say blowing thats what I mean, the bulb is shattered. I thought it was a short, but the fuse is fine and the side marker bulb on that side works fine, any help would be appreciated, electrical stuff is not my forte.
Old Apr 28, 2008 | 03:49 PM
IRONFIST's Avatar
If the bulb is exploding, that's usually because water is getting into your light assembly. Look for a crack in the plastic that might be letting water in? If there is one, use some epoxy, seal it up, and dry out the inside. Also make sure the light socket is sealing properly.
Old Apr 28, 2008 | 04:43 PM
IXLR894Z28's Avatar
How hard are the light assembly's to remove?
Old Apr 29, 2008 | 10:30 AM
Compstall's Avatar
You can get at it from under the bumper cover John.
Old Apr 29, 2008 | 07:15 PM
gnomee's Avatar
Real easy. Like said above you can get to it from below.
You may also want to replace the socket gaskets. If its happening that often you probably have a crack in the lens. You could just be missing a gasket though.
Check out http://www.autotrix.net/product_page...imegasket.html
Old Apr 30, 2008 | 06:31 AM
IXLR894Z28's Avatar
Thanks Brent and everyone else, I'll check it out this weekend.
jayblev95
Jun 7, 2015 04:04 PM
camaro98_speed
Apr 22, 2015 11:26 AM
alex5366
Feb 17, 2015 10:43 PM
