15X10 or 15X8 Rims for hoosier 275-60-15
Old Apr 27, 2008 | 07:38 PM
hankisonc's Avatar
Hey everyone getting ready to purchase rims for my Drag radials and I was wondering if everyone could help me out here. I have stock ride height and i just want to make sure i get the best possible fit for my track set up. What rim should i use and what back spacing is going to be the best for fitting this 28" under my car. I see that jegs recommends 8-10 wide rims which is better.
Old Apr 27, 2008 | 08:38 PM
hankisonc's Avatar
the car is a 1993 z28 if that helps
Old Apr 28, 2008 | 04:20 PM
The recommended wheel width is set by the tire manufacturer. The Hoosier website info indicates the tire will work OK with anything from 8.0" - 10.0" wide. Its a tossup.... Hoosier is saying either is fine.
For a 15x8" wheel, you want a 5.5" (even with edge of fender) or 6.5" backspace (in about 1" from edge of fender). For a 15x10" wheel, you want a 7.5" backspace (even with edge of fender).
Old Apr 28, 2008 | 08:01 PM
hankisonc's Avatar
thanks great info
hey thanks for the advice. I just wanted to make sure to make the right choice. So the 15x8 will allow the hoosier's to hook as good as the 15x10? what about side wall wrinkle. thanks again. Hey its good to see someone else running the thm 400 set up!!!!!!!!!!
Old Apr 29, 2008 | 09:09 AM
I always ran a wider wheel, where possible. 16 x 9.5" with some ET Streets, 15x10" with what I have now. My thinking is you are only going to want to go wider as you up the HP, so just get the 15x10's to begin with. But I don't have enough experience to know if the 8" or 10" would provide the best footprint, and I've never run drag radials on the track, only on the street.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
Formula Steve
Sep 19, 2015 08:48 PM
rvonsternberg
Sep 14, 2015 11:58 AM
scottcba1
Sep 8, 2015 09:52 AM
