stalling problems
Old Apr 25, 2008 | 12:47 AM
romans4l's Avatar
stalling problems
88 Iroc with 5.7. This issue has been going since the beginning of last summer. Car runs great but stalls when down shifting and rpm drops suddenly below 1k...this usually occurs when slowing to a red light. fuel pressure is good, fuel pump seems fine. just replaced IAC valve.
Any advice on where to start would be much appreciated...
Old Apr 27, 2008 | 03:14 PM
derbs's Avatar
Whens the last time you did a tune up to the motor? It also could be youe tps its a start.
Old May 1, 2008 | 01:07 PM
mrcamaro1956's Avatar
check your distributor see if you have any play in it.i had same trouble, i took mine out and it had a bad innner bushing. it messed up the timing causing stalling. take off the cap and grab the rotor see how mush play there is. how many miles on your engine ? hope this helps
Old May 3, 2008 | 05:14 PM
king1138's Avatar
check your mass air flow sensor! it's often neglected, but even a small amount of contamination will make your car run bad, stall, and get ****ty fuel economy.
james007moore
Jan 1, 2016 01:14 PM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
greenzee28
Mar 26, 2015 09:13 AM
marine1bird
10
Jan 25, 2015 12:02 AM
edxiel
Jan 24, 2015 07:40 PM
