wiring an a4-m6 swap
Old Apr 10, 2008 | 08:47 PM
ablackcamaro's Avatar
Down to the final step of the conversion and driving the car is a blast
But I'm trying to get the reverse lockout solenoid to work, and when testing wire d6 (blue connector) from the pcm, it has a constant ground. My wiring diagrams show me this should be the wire the pcm uses to switch ground for the reverse lockout. Yet the wire has a constant ground, with key off, key on, vss at 0 mph or at 30 mph and in second gear.
The factory pcm has been somewhat disabled to piggyback a fast bank to bank unit, but still has vss and brake signals (clutch pedal is also wired in to cruise control system.)
Using tunercat, I've turned off all automatic related diagnostics in the switch tables, and have successfully re-calibrated the speedo. Is this not enough, do I need an actual m6 program? Any help appreciated, I'd like to get this working 100%
Old Apr 10, 2008 | 09:46 PM
sbs's Avatar
sbs
I would think so, but no personal experience.
Old Apr 10, 2008 | 10:40 PM
MEAN LT1's Avatar
I havent tried to make my reverse lockout work but the only thing you need is a power and ground to make it work. Why not just make a seperate button for it to activate it?
Old Apr 10, 2008 | 11:21 PM
I just want the car to seem as if it came from the factory with a 6 speed (minus the skipshift.) And the reverse lockout is a big part of it. I'm considering looking into some kind of mph-based window switch that can switch the solenoid, so you can only shift into reverse say below 3 mph, but since the factory computer already has the capability, why not just use that? I think it would be a pain to have to hit a button while trying to get it in reverse, you'd be pushing in the clutch, using the shifter, probably turning the steering wheel and now have to press a button too? It's just too much lol..
Does anyone know the actual specs at which the pcm sends the ground to the solenoid? What the mph limit is, if the brake has to be depressed, etc?
Old Apr 11, 2008 | 08:21 PM
rngilliland's Avatar
Yes you need a 6-speed program. The auto and m6 programs use some of the same pins for different things and as far as I know the only way to make everything work correctly is to use the m6 program. Just changing things on an auto program won't work.
Old Apr 11, 2008 | 08:32 PM
makes sense, nothing to really lose by trying... anyone have a 95 m6 program? tomnjery@optonline.net if you don't mind, tia..
Old Apr 16, 2008 | 07:25 PM
update: i tried a bin file from a 95 manual, and the wire still has a constant ground. has anyone successfully converted from auto to manual and gotten the reverse lockout solenoid to work?
Old Apr 17, 2008 | 08:43 PM
I converted my 94 using a 94 m6 bin and the reverse lockout worked normally. I used the #6 pin on the blue connector like you did and the hot wire from the reverse lights. Tunercats shows it enabled at 5 mph and disabled at 4 mph. I think that means as you accelerate it is disabled at 4 mph and as you slow down it is enabled at 5 mph. I just hooked mine up and it worked. I could hear the solenoid click when I turned the key. I guess its possible your pcm is damaged or the piggy back computer is affecting it some way.
Old Apr 17, 2008 | 09:15 PM
in what table of tunercat did you find the 5 and 4 mph settings?
Old Apr 18, 2008 | 07:05 AM
There is a separate table in the far right column of tables. I think this is new. When I did my conversion I think it was in the constants and only had the 5 mph figure but I don't see it in this version of tunercats.
Old Apr 18, 2008 | 09:08 AM
bond2's Avatar
I had the same issue on my 96, and I even switched my PCM to a 96 M6 program. We gave up and just removed the solenoid lock, but I think we left in the springs so when shifting into reverse it was a little tougher than the other gears. In the 8 months since I did the swap I only accidentally bumped the reverse gear twice, it starts to grind immediately, though I am sure excessive grinding could do some damage. I'd be interested to hear if and how you get it to work.
Old Apr 18, 2008 | 07:11 PM
bond2 ... i've been through a lot of problems getting this conversion to work. after two different used trannies, each w/ diff synchro problems, i finally went to rockland standard gear and got a rebuilt unit. im not looking to damage another one lol, and with a short throw, 6-5 is too easy to move over the extra gate to r (already happened once)...
i updated tunercat to version 2.18 and with the manual bin file loaded, i still see all the auto tables and nothing mentioning anything to do with a manual transmission. should a manual file load different tables?
Old Apr 19, 2008 | 08:19 AM
Ricardo's Avatar
I assume your harness is the original A4 harness.
I have not done a conversion myself, but think you could check the following:
What did you do with the remote hatch open circuit?
The ground to the hatch release relay is normally supplied by the P/N switch found in the A4 shifter mechanism. This ground is also supplied to the PCM thru terminal C15 (only in automatics).
When you scan an M6 car and check for gear it should allways read 1st gear (if I remember correctly), no matter what.
Old Apr 19, 2008 | 08:51 AM
at the safety neutral switch i joined the org/blk and blk/wht wires together, which should show the pcm connector c15 a constant ground. you think that may be my problem?
Old Apr 19, 2008 | 08:56 AM
Ricardo's Avatar
Might be. You could undo that splice on the P/N switch connector and try it. Your hatch release wont work, but you can fix that by removing wire C15 from the PCM connector and re-doing the splice. Scan the car an see what gear the PCM reports.
