Has anyone fixed the jet hot slip fit primary?
Old Apr 5, 2008 | 12:32 AM
ssbowtie1's Avatar
What a lame design by Hooker/Jet Hot. After reading endless threads I tried using a 1 3/4" tbolt clamp and that did absolutely nothing. I've seen other posts recommending different kinds of sealants. Has anyone had any long term positive results with anything? The last option I can think of is to take the header off and notch the primary and try the tbolt clamp again.
Oh and anyone that doesn't think their slip fit is leaking, turn the car on and hold your fingers near the slip fit primary. You might be surprised.
Old Apr 10, 2008 | 10:29 PM
ssbowtie1's Avatar
No one?
Old Apr 10, 2008 | 10:31 PM
mdacton's Avatar
Mine has never leaked......
put some orange silicone on it
Old Apr 11, 2008 | 09:16 AM
OutKast's Avatar
I haven't heard mine leak in 10 years but I can understand where it could leak when cold. The way I understand it is that the expansion from heat should seal it up good. I figure if it were leaking I would also see a bunch of carbon in the area.
Old Apr 11, 2008 | 10:17 AM
Pontiac_97's Avatar
3" band clamp. no more leaky leaky just overlap the joint and it will contour to the pipe once you torque it down
Old Apr 11, 2008 | 10:32 AM
MEAN LT1's Avatar
No leak in 7 years.
Old Apr 11, 2008 | 11:54 AM
Kaj's Avatar
Kaj
Old Apr 12, 2008 | 07:19 PM
my96z's Avatar
No leaks here and I didnt even use a clamp.
Old Apr 14, 2008 | 11:46 AM
red 95 z28 lt1's Avatar
mine leaks, tried rtv and a t band clamp but not over the actual leak
F'n1996Z28SS
Aug 23, 2023 11:19 PM
mattstrike
Mar 11, 2015 07:33 PM
LT14LIFE
Feb 9, 2015 09:35 PM
MislMan
Jul 19, 2002 11:41 AM
