Difference in single cat and dual cat header/y pipe
Old Apr 3, 2008 | 07:12 PM
stockssn2o's Avatar
i have a 97 ss with shorties on it now with the stock y pipe and gutted cats. I bought a set of longtubes for it but they are for a 95 single cat.... what am i gonna have to do about the y pipe? whats the difference?
Old Apr 3, 2008 | 07:21 PM
2000GTP's Avatar
It doesn't matter if you have a stock single cat y-pipe or a stock dual-cat y-pipe, neither of them will work with long tube headers due to the dimensions. What brand long tubes did you buy?
Old Apr 3, 2008 | 07:22 PM
stockssn2o's Avatar
they are jet hot... i have a y pipe in 5 pieces ... i just wanna know the difference in the two ...
Old Apr 3, 2008 | 07:24 PM
2000GTP's Avatar
they are jet hot... i have a y pipe in pieces ... is it gonna bolt up or what ...
If it is the jet-hot long tube header y-pipe then it will bolt up. If it is a stock y-pipe, it will not.
Old Apr 3, 2008 | 09:01 PM
stockssn2o's Avatar
i did a search the AIR fitting is different and the 97 has rear o2 sensors...which isn't a problem because the rear o2s are turned off on my car
Old Apr 4, 2008 | 06:58 AM
2000GTP's Avatar
If they are the "race" headers, it won't be an issue considering they won't have the AIR and EGR fittings.
Old Apr 4, 2008 | 10:48 AM
LJM97Z's Avatar
I just got an ORY pipe for my 97.
BTW, how did you turn off your rear o2 sensers ?
Old Apr 4, 2008 | 11:27 AM
The rear sensors have to be eliminated in the PCM programming. Or replace them with "sims", if anyone is still making them.
Old Apr 4, 2008 | 01:35 PM
stockssn2o's Avatar
they aren't race headers they are emmisions legal
we turned them off when i got it dyno-tuned...
Old Apr 4, 2008 | 02:10 PM
Green96Z's Avatar
96-97 cars have different AIR fittings than previous years. And if you're going with an ORY and already had the rear O2s deleted, then y-pipe doesn't matter, as long as it bolts up to your catback.
Old Apr 4, 2008 | 05:44 PM
2000GTP's Avatar
They are alot harder to find, although I know of a couple of vendors in which I purchased a couple sets from to keep on hand. If you are interested in the links for your own personal reference, I can PM you them.
QuickSilver02
Apr 7, 2015 11:12 AM
alphaauto
Jan 22, 2015 08:02 PM
tubby
Oct 13, 2003 09:16 AM
BM93Z
Aug 22, 2002 02:45 PM
