aftermarket guages
Old Mar 31, 2008 | 06:32 PM
blubird's Avatar
aftermarket guages
im looking at getting an aftermarket oil psi and fuel psi guage, what are the pros and cons of an electric or mechanical guage ?
Old Mar 31, 2008 | 07:22 PM
CALL911's Avatar
You will have a hard time finding any electrical units as most fuel pressure and oil pressure units are mechanical. However if you did, the electrical guages are usually much more expensive, however they are also much more accurate, and sometimes have nice features such as recalling max pressure, and some even have warning lights you can preset to a certain pressure level warning you before you reached a critical pressure level.
Old Mar 31, 2008 | 08:31 PM
blubird's Avatar
oh cause ive always heard that mechanical were more accurate, but yes i have noticed electrical were more expensive
Old Mar 31, 2008 | 10:16 PM
Electronic fuel pressure gauges are fairly common. AutoMeter has been making them for at least 10 years. They have both high cost, full-sweep (270*) and low cost 90* sweep electronic units. Take a look at the current online AutoMeter catalog.
You can't install a mechanical fuel pressure gauge in the passenger compartment, unless you use a high pressure isolator at the firewall, to prevent fuel from entering the passenger compartment. Keeping the isolated side of the system filled with glycol is a major PITA, leading to bad pressure readings. I had a mechanical gauge for a while, and the AutoMeter high pressure isolator failed, and allowed fuel into the line to the gauge. I would stronlgy recommend not using a mechanical fuel pressure gauge inside the car. If you have to use one, mount it on the hood,
I honestly do not believe you can claim electronic or mechanical are more accurate. I've seen more electronics with problems, though. I run a mechanical oil pressure gauge, mechanical nitrous pressure gauge (with flow restrictor), electronic fuel pressure, electronic oil temp and electronic tranny temp.
Kinglouui
May 26, 2016 11:05 AM
IndyZman
Oct 22, 2015 02:17 PM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
CARiD
Sep 30, 2015 05:44 AM
SEOJustin
Sep 24, 2015 04:39 PM
