wheel stud question
Old Mar 30, 2008 | 09:01 PM
scott5's Avatar
wheel stud question
I am sticking with my slicks and skinnys and decided to upgrade my studs in the back. What you guys recommend getting? Also coudl you tell me which lug nuts to go with them? I have stock axles and stock rear end.
Old Mar 31, 2008 | 08:45 AM
Without knowing the brand of the wheels, I don't see how anyone can answer your question. Do they use conical lugs or shank style lugs?
Old Mar 31, 2008 | 12:36 PM
scott5's Avatar
oh, sorry i forgot to add that.. They are Weld Draglites 15x10 with 6.5 in back spacing
Old Mar 31, 2008 | 01:30 PM
blue 79 Z/28's Avatar
direct replacement is arp #100-7708 wheel studs. those are the shorter of the 2 avail. 2.5" i believe. keeps the metric bolt pattern. ARP #100-7713 are 3.25" long they are both 12mm x 1.5
Old Mar 31, 2008 | 01:49 PM
scott5's Avatar
thanks
Old Mar 31, 2008 | 01:55 PM
And you use the same Weld long shank lugs you already have, no matter how long the studs are.
With 3" studs on mine (1/2-20 screw-in), the ends of the studs stick about 3/8" out of the end of the lugs.
Airplanedoc
Feb 1, 2015 07:14 PM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
Catmaigne
Dec 25, 2014 12:16 PM
ChrisFrez
Nov 30, 2014 08:41 AM
sseeya
Aug 8, 2002 11:37 AM
