Jet Hot header gasket questions
Old Mar 30, 2008 | 07:04 PM
94zgreenmachine's Avatar
I have some Jet Hot headers that I thought were sealed up good. After taking the engine apart to find the clips from my comp r lifters, I noticed some black around exhaust ports on #8 and #'s 3&5. I didn't want to use the paper gaskets cause I was afraid of them not sealing. Instead I used percys dead soft gaskets. Ialso used them on the collectors. They sealed excellent on the collectors. All the bolts were tight and I always rechecked them. This build only had 2000 miles, if that.
Nothing wrong with the header flange. What is a good gasket to use that will seal? Does any one use the hi temp sealant? I don't want to use that cause I should not have too in the first place. Any help would be appreciated.
Old Mar 30, 2008 | 07:20 PM
2000GTP's Avatar
I used FelPros sprayed with the copper high temp spray. I've had no sealing issues.
Old Mar 30, 2008 | 07:26 PM
I have never heard of this hi temp spray. I assume it can be had from any of the parts stores? After the percys, I am at a lost for sealing. I thought for sure those were the cure all. Is there anything out there that will "crush" better? I bet those gaskets would have worked better on iron heads.
Old Mar 30, 2008 | 07:39 PM
2000GTP's Avatar
Yeah, it was that Permatex spray, pretty sure I got it at Autozone.
Old Mar 30, 2008 | 07:40 PM
Thanks, I'll give that a shot.
Old Mar 30, 2008 | 07:42 PM
dangalla's Avatar
either those or the factory gaskets from the dealer should be fine
Old Mar 30, 2008 | 07:45 PM
I still have the jet hot gaskets, if I look for them. It has only been 4 yrs....Thats how long it took me to put in the relay for my SS spoiler problem!
LT14LIFE
Feb 9, 2015 09:35 PM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
RedLineRev
Jan 23, 2003 03:51 PM
