121,200 Miles...Bye, Bye Radiator
Old Mar 14, 2008 | 02:28 PM
WestCoast96Z28's Avatar
Nothing important in this thread, just making a statement.
Well, it had to break sometime. After a trail of orange-ish fluid in the driveway and some steam leaking from the hood...the radiator has given in.
Not to bad for a 12 year old car though. There's a slight crack on the passenger side right above the low coolant sensor. Hopefully the next radiator will last another 12 years!
Old Mar 14, 2008 | 02:37 PM
2000GTP's Avatar
You're at the mileage where stuff starts breaking.
Old Mar 14, 2008 | 02:59 PM
shoebox's Avatar
Thanks for the update.
Old Mar 14, 2008 | 08:56 PM
Interceptor1's Avatar
Lucky you, mine just let go at 67k. It started to leak where the fitting of the auto trans line is, near the coolant sensor. I replaced it as well as the upper and lower hoses, but now my temp gauge is not steady as before.
I don't know if this is normal, but it rises when idling at a stoplight but goes down when the engine is revved up once underway and with better ariflow. My coolant level is going down every 5 days or so though, but I don't know where, there are no apparent leaks and no white smoke in the exhaust.
It sucks, in 3 Camaros I've had (2nd, 3rd. 4th gen) all three had radiator problems. I can't wait to change a radiator in a 5th gen.
Old Mar 15, 2008 | 12:05 AM
Fuels94TA's Avatar
Not bad at all...My 94 gave out last year when I hit a pot hole and crack the tank.
Old Mar 15, 2008 | 12:06 AM
dangalla's Avatar
lol, yeah its about that time, i am in the same boat. you gotta pay to play
Old Mar 15, 2008 | 09:34 PM
95camaroinok's Avatar
interceptor, either you didnt get all the air out of the system, water pump is goin out, or your thermostat is bad. If all of that checks out good, could still be a gasket, they dont always start blowin white smoke out the exhaust as soon as it happens. How much are you having to add each time?
also, some increase in temp with these is expected when sitting still.... but not too much. Shouldnt get any higher than around 230* if your all stock. Might want to invest in a real temp gauge. That was one of the first things mine got, factory gauge is too vague.
Old Mar 16, 2008 | 01:29 AM
rbaksi's Avatar
Yeah I do hate the early 100Ks things tend to break a lot. Currently I'm in a love/hate relationship with my car lol.
But the good thing is, all the stuff you're replacing means a lean mean mustang beasting machine for another 100K....hopefully
Old Mar 16, 2008 | 07:13 AM
2000GTP's Avatar
Depends which Mustangs you decide to play with.
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
Daluchman1974
Sep 11, 2015 06:12 AM
CARiD
Sep 7, 2015 08:21 AM
Pwilson59
Sep 3, 2015 08:47 PM
