wtb z28
Old Mar 8, 2008 | 04:19 AM
jj71787's Avatar
wtb z28
im looking to buy a z28 preferbly for a trade plus cash i have a 98 camaro v6 with 113,000 miles im located in new york
Old Mar 13, 2008 | 06:52 AM
spinout's Avatar
trade you your car and 12000 for my 1981 z28 if interested send me an email ill send pics and info crashedta1974@hotmail.com
Old Mar 17, 2008 | 08:10 PM
eddies26's Avatar
95 12 second camaro
Let me know what you think if interested I can send some pics.
I built this to keep forever so everything that went into it was the best I have only 1500 miles on it since everything was put back together.
looking to get 5000 picked up in maryland.but send offers. Email if intersted I can send pics.This has been mid 12's on bad street tires the engine is built for a 200 shot. I have invested close to 15k in the car over the last 3 years. The car needs roller rockers adjusted. (never wrapped up after I reinstalled engine last winter)So review let me know if your interested.
eddie
240-216-0063
esymonds1@comcast.net
95 z-28 106000
built 96 vette 4 bolt main block
forged 30 over pistons
11.0-1 comp
shot peened rods
arp rod bolts
stock crank size(was perfect when rebuilt)
high pressure gm oil pump(holds 45 at idle 65-70 at 2000)
6 quart vette oil pan
lt4 cam kit with gm roller roackers
manley valves
hardenes comp pushrods
new gm perf parts lifters
stock lt1 heads port matched to intake
jett hot coated intake manifold
jett hot coated edelbrock shorty headers
58 mm edelbrock throttle body
all new sensors
egr removed & blocked off
polished valve covers with correct notch for alternator
moroso cold air intake
new vented optispark upgrade
taylor 10mm wires
new ac compressor
new ac lines
repainted engine compartment
aluminum radiator
steel braided transmissions lines with all fittings
lt1 edit program with customer flash cable
built auto 4l60e with extra clutches shift kit installed
new u joints (stock drive shaft)
stock locking rear
new brakes up front(calipers,pads,rotors,brake lines)
new suspension techniques bushings front & rear
new ball joints tie rods
traction bars
KYB AGX adjustable struts & shocks front & rear
new strut boots
new steering rack
abs removed & proportioning valve installed with line lock kit(steel needs to be wired up, still have abs if you want to reinstall)
new battery
magnaflow stainless exhaust cat(sounds mean)
INTERIOR
swapped beat beige leather for late black interior
swapped in 98 up dashboard & stereo(monsoon bose system sounds great)
98 up center console
98 trans am buckets in perfect shape & rear seat also
t-top shades(grey but can be dyed)
interior complete assembled all power options work except locks
TitoPR221
Parts Wanted
Jan 10, 2015 09:21 AM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 12, 2014 10:51 PM
