Please check my 9" ring / pinion gear pattern. Am I ready to go?
Old Feb 1, 2008 | 07:42 PM
wrd1972's Avatar
Okay, I think I have nailed the pattern on my 9" Motive performance ring and pinion setup. I killed the older thread so there would be no more confusion, plus I had the many photos mixed up. Thanks again to all who have helped.
The following setup use a .019" total shim pack and has .008" backlash.
Please check these patterns out, am I ready to go?
Drive side
Coast side
Old Feb 1, 2008 | 08:17 PM
mdacton's Avatar
Can you get another pick of the thrust side? It looks a little deep but kind of hard to tell
Old Feb 1, 2008 | 08:28 PM
wrd1972's Avatar
I guess I am confused, what is the thrust side?
Any other suggestions for a better picture.
Old Feb 1, 2008 | 08:29 PM
mdacton's Avatar
Bottom pick, I meant coast......I'm half asleep
Old Feb 1, 2008 | 08:40 PM
wrd1972's Avatar
Another shot of the .020" coast side.
Here are some other pics for reference showing .020, .021, .022, shim packs.
Gears are Motive Performance for the 9".
.020"
.021"
.022"
Looks like adding shim is moving the drive pattern to the heel as well as moving the two patterns apart. Once again guys all the pics in my old deleted thread are bogus, they are totally worthless.
I checked the backlash at .008" and .0012", the change was nearly non-existant. Are the two patterns supposed to be more centrally placed rather than spread apart?
Now what?
Old Feb 3, 2008 | 04:27 PM
wrd1972's Avatar
Update:
Went with the .020" shim pack and a .009" backlash and it is very quiet. What noise I am getting is being amplified by the tunnel mount torque arm. The final pattern certainly was not 100% ideal, but it was certainly the best I could get.
Thanks to all that helped.
Old Feb 3, 2008 | 04:50 PM
mdacton's Avatar
The way some gear sets are cut for strength so they make a little noise anyway. I have a Pro Gear set...its noisy as hell, and I have rod ended TQ arm and heim joints on everything
oldschool
Feb 9, 2016 09:21 PM
TitoPR221
Jan 29, 2015 08:00 PM
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
