limited slip
Old Dec 12, 2002 | 04:15 PM
mook99TA's Avatar
limited slip
How do you know if you have a limited slip differental? Also been haveing problems trying to check my rear end oil. How do you do it?
Old Dec 12, 2002 | 04:28 PM
Freak's Avatar
jack the backof the car up, in neutral, rotate one tire. If the other tire rotates in the same direction you have a limited slip (it wont rotate in park/gear)
If your rear end is stock, I can tell you now you dont have limited slip, you have a torsen.
to check the oil you simply pull the fill plug on the side, and stick your finger in the hole, the fluid should be right at the botom of the hole. if its not, add till it starts to come out...
Old Dec 12, 2002 | 11:50 PM
mook99TA's Avatar
thanks lots of help.
Old Feb 10, 2004 | 08:01 PM
cop_camaro's Avatar
According to my door sticker mine is a GU8 which is limited slip!
In checking with Chevrolet by VN it's a limited slip.
Whats the difference in the two
IndyZman
Oct 22, 2015 02:17 PM
Sep 11, 2015 09:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
