MAF cleaning?
Old Jan 27, 2008 | 04:35 PM
camaroLevi's Avatar
Question MAF sensor cleaning possible/or not?
i was reading that you can clean the little strand of wire that heats up in the MAF sensor, one is this true?, and 2 is this possible to do with a q-tip and a cleaner?
Old Jan 27, 2008 | 09:45 PM
chevynutman's Avatar
in most cases you can clean it but dont touch it get some throttle body cleaner and spray it lightly but if that doesnt work than it is no good
if it is giving you a hard time but you cant get one just unplug it you should be able to drive around liks that for a while and most cars will run better with it unplugged than having a junk one hooked up
mine has been unplugged for about a month now
Old Jan 28, 2008 | 07:53 AM
2000GTP's Avatar
Some parts stores will sell the MAF cleaner. I think others just use electronics cleaner. Just be very careful if you do run a Q-tip over it as that wire is very fragile. If your wire is contaminated, cleaning it should improve the drivability of the vehicle.
Old Jan 28, 2008 | 07:56 AM
camaroLevi's Avatar
Talking thanks guys
hey that was some helpful info thanks ,i'll be doing that when i get home from work today, thanks again! ~LeVi
95blkss
Parts Wanted
Jul 19, 2015 08:42 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Noct
Jul 14, 2015 01:18 AM
