don't want to get wrong injectors
Old Jan 23, 2008 | 07:56 PM
caper's Avatar
I'm putting afr lt4 heads, cc xfi268 cam , roller rockers, 58 mm throttle body and exaust to stock bottom end. I think 30lb injectors will work fine but next year i will replace with 383, or should i go with 42 lb or will the 30lb be fine for what I hope would be in the 500 fwhp range.
Old Jan 24, 2008 | 07:38 AM
Rough guideline that works pretty well, in lieu of actual engine dyno BSFC for your engine is to multiply flywheel HP by 0.07 to get your minimum injecotr size. That assumes a moderate 0.476 #/HR/HP BSFC and a maximum duty cycle of 85%.
Sizing the injectors for your future needs.....
500 flywheel HP X 0.07 = 35 #/HR
....minimum. Larger will not hurt.
Old Jan 24, 2008 | 10:09 AM
caper's Avatar
thanks for info I will look at that range.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
siguy
Nov 27, 2014 10:07 AM
