Fuel pressure problem
Old Jan 21, 2008 | 06:20 AM
97_camz28's Avatar
just rebuilt my LT1 and got it running, but i have a fuel pressure problem, with the key on engine off it will pressurize up to 43lbs and instantly drop off to 0. and it is running very rich. i have racetronix 255lph pump, 30# svo injectors. the fuekl pressure regulator seems to be working fine, and there is no fuel in the vacuum line for the fuel pressure regulator. when i turn the key on to pressurize the system it sounds like an injector is squirting badly, but i pulled the rail up and and tried it and none are leaking, i also have checked all the o-rings and oiled them well before i installed the injectors, and have double checked them.....i am stumped????? the computer has been tuned for the injectors....thanks
Old Jan 21, 2008 | 08:20 AM
AL SS590 M6's Avatar
You have an injector that is sticking open.
Old Jan 21, 2008 | 02:12 PM
97_camz28's Avatar
thats what i thought but when i pulled the rail and injectors out of the intake ports, i turned the key on and no fuel sprayed out of any of the injectors and i still lost all the fuel pressure right away???
Dec 1, 2016 05:37 PM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
Alex Barnes
Jan 24, 2015 10:21 PM
