74 camaro 350
Old Jan 18, 2008 | 04:15 PM
swollwick's Avatar
74 camaro 350
my car's starting to have a serious problem. It's sort of backfiring, but most of the time it's more of a popping. It doesn't do it every rotation, it's sort of sporadic. Just changed all the plugs and wires. And it sounds like there's no skip at all. Any thoughts? Thanks for the help
I cut the pipes just in front of the mufflers. could this be my problem? I've been told that could mess up my valves
Old Jan 18, 2008 | 09:52 PM
angel71rs's Avatar
When did problem start, b4 or after plug/wires change, b4 or after you cut the pipes? Anytime I hear of a mid 70s chevy starting to run rough, I always ask if it still has stock cam in it. They had problems with lobes rounding out in those years, but never personally seen it on a 74.
Cutting back pressure can lean it a bit, but not enough to burn any valves. You would have to have been lean to start with.
Old Feb 23, 2008 | 12:42 PM
byrons1502's Avatar
sounds like a valvetrain prob. with the newer oils they have less zinc and is killing alot of hydraulic cams. i would not be surprised to see a worn lobe or sticking valve. we just had a 70's 440 have a bent pushrod doing the same thing. pull the valve covers and rotate the engine while watching the rocker arm.
Old Feb 25, 2008 | 10:28 AM
Z28SORR's Avatar
I'd check out the rest of the ignition before I jumped into the valve train.
Have you check the cap/coil and rotor, timing, timing advance, etc?
I think the "zinc" problem has been way over stated.
Old Feb 25, 2008 | 06:37 PM
byrons1502's Avatar
just had a brain fart. check for a lean back fire first. ignition system second. camshaft third
Old Mar 4, 2008 | 01:51 AM
jasonspd's Avatar
I had a hell of a time finding an intermittent backfire in my '69 Camaro a few years ago. It was rare and only backfired once every 15 minutes or so and it ran fine. Turned out to be a bad condenser in the distributor. Just a thought.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Collector Car
Dec 17, 2014 01:12 PM
CaRParts102
Dec 6, 2014 08:45 AM
