Double Hump Heads 327
Old Jan 18, 2008 | 01:13 PM
mike85z28's Avatar
I was told that all 327's came with the Double Hump Heads, is that true?
Old Jan 18, 2008 | 01:38 PM
takeoffeh's Avatar
307 or 327?
Your heading said 327. If that's the case, no, not all 327's came with double humps. Some came with the same "power pack" heads on 283's, w/ 1.72" int. Worse yet, some came with 1.72" int with the large chambers that were common on the 70's "smog" 350's and 400's. But a good bit of them did get the double humps.
Old Jan 18, 2008 | 02:55 PM
mike85z28's Avatar
Sorry typing error. Yes its a 327. All I know about this motor its a 60's model and It came out of a Corvette. So I guess its a pretty good chance it has the humps. I'm waiting on my uncle to get the info for me. Or I guess I'lll find out when I get this motor.
Old Feb 21, 2008 | 03:47 PM
byrons1502's Avatar
why do you want to know. if it is for a resto double humps are ok but for performance they suck... that will **** some old timers off. but not all 327s came with double humps. double humps also came with a variety of cumbustion chamber sizes and valve sizes. very few came with 2.02 valves so be careful
Old Feb 23, 2008 | 09:46 AM
mike85z28's Avatar
I'm not going with the double humps anymore, I am going to go with a set of Dart Iron Eagle Platinum heads. From what I have been hearing, these are pretty bad ***!!!
Old Feb 23, 2008 | 12:24 PM
byrons1502's Avatar
combine the heads with a performer rpm and 650 carb, decent cam you will get a very streetable 400hp
11secgen's Avatar
make sure not to get crazy with inake port size.200 cc is pretty large for a 327.that would be for an all out racing ,high rpm motor, but i bet you have a forged crank in that 327, so go ahead and spin it to the moon!i was just reminding you to be conservitive on cam selection and port size because the slightly lower displacement of the 327 will make these things ''act'' bigger.
Old Feb 23, 2008 | 02:07 PM
mike85z28's Avatar
The motor is bored .030 over and I'm getting the performer intake and carb combo from summit. 650 carb with the air gap intake. The cam I'm undecided. Any suggestions??
Old Feb 23, 2008 | 02:13 PM
mike85z28's Avatar
What exactly do you mean "act" bigger. What size do you suggest??
These are the heads SBC CHEVY Dart Iron Eagle Platinum Heads
200cc / 64cc / 2.02/1.60 valve / straight plug. Thanks
Old Feb 24, 2008 | 08:28 PM
byrons1502's Avatar
what is this going in. car,weight,trans, rear gears,compression(true flat tops or 2 or 4 valve reliefs) i like the 200cc heads because when you do go faster the heads are the most expensive part. what he is talking about is with the larger heads your port velocity will be lower and kill the low end torque with the small cubic inches. it will rev to the moon but be lazy on the bottom end. matching your combo to the car can make this fun to drive...
what is the goal of the car? street or strip or fast street? this could be fun
the carn selection depends on the carb. some of the kits come with the holley 1850 series and they suck for performance.
Old Feb 25, 2008 | 07:16 AM
mike85z28's Avatar
It is going into an 85 Z28. As for the goal, I want a fast street, and not to get blown away if I take it to the strip. It has a 700R4 tranny built with a shift kit, and I'm installing 4:10 rear gears. The intake,& carb are going to be edelbrock.( Performer air gap & 650cfm performer carb) Dart heads 200cc, 64cc with 2.02/1.60 valves. Still undecided about what cam yo get. Any suggestions on the cam? Or cam kit with lifters?
Old Feb 25, 2008 | 09:02 PM
byrons1502's Avatar
Thumbs up
as far as the cam goes the comp xtreme cl12-246-3 it will be very streetable but give a real nice kick. i would also get a 2000-2300 stall converter. it will be easy on the street. go much bigger on the cam and it might be slightly lazy on the bottom end with the larger heads. i would go with 3.73 gears. it will keep the rpms down to around 250 rpm cruising at 60-65 and not overrev the engine on the top end of the track. check the heads i think the springs are a little strong for that cam. if you going with the edelbrock carb you could go with a 750 and not hurt drivability. get a tuning kit it may be a little rich at cruise speeds.
this would be a decent street setup that even your mom could drive. if you wanted a hot street i would go with a 2800 stall and a cl12-254-3 kit. gas mileage and manners may be a little rougher. then you could use the 4.11 gears because you should be at 6500-6800 rpms
go with the performer rpm ari gap not the standard performer air gap. big diff
Old Feb 25, 2008 | 11:30 PM
mike85z28's Avatar
I can get a combo from edelbrock Peformer RPM Air-Gap manifold with a thunder series 800cfm carb. Do u think 800cfm is too much?
Old Feb 26, 2008 | 07:24 PM
byrons1502's Avatar
the good part about the thunder series is they have a lot of adjustments. the edelbrock carbs you can go big and still have the same driveability. i would recommend a tuning kit though it will be a little rich. most quadrajets are 750-800 cfm. the edelbrock is not the best for all out performance but i have ran a 750 edelbrock on a 11 second z. they are one of the easiest bolt and go carbs. that will be a great combo
Old Feb 27, 2008 | 12:54 AM
mike85z28's Avatar
This may sound really stupid but will this cam fit any set of heads that I put on? What if I don't go with the 200cc Darts? I'm just getting into all this, so my knowledge of building a motor and trying to modifiy everything is very slim. I would apperiate all the advice I can get.
