what size shot?? yes again.
Old 12-27-2007, 01:44 PM
kline454's Avatar
Im running a 355 11.7cr cc306 stock heads,srp forged pistions, egale H-beam rods and 4340 forged crank. 2bolt block with arp studs, Last year i was spraying a 100shot i want more but dont want to break the block how much more can i go??
kline454 is offline
Old 12-27-2007, 02:30 PM
Ray@NitroDaves's Avatar
I suggest talking to your engine builder and SRP as they would be able to get you a better Idea of the limits of your components
Ray@NitroDaves is offline
Old 12-27-2007, 02:34 PM
texas94z's Avatar
people spray a 150 shot on a lt1 with stock internals. go to a 300 shot and see what happens. theres a reason why after market companies make forged internals. btw congrats on that new motor.
texas94z is offline
Old 12-27-2007, 03:33 PM
But I have seen ring lands break off forged piston because the rings were set up for NA use, not for the extra cylinder pressure of nitrous.
One of my friends destroyed a fully forged 383 on a 100 shot
Old 12-27-2007, 03:39 PM
HardcoreRM125's Avatar
If its built for it ( Ring gap ), id go bigger, Id do a 300 shot. But id do it on a progressive controller or a dual stage set up for sure
HardcoreRM125 is offline
Old 12-27-2007, 05:11 PM
texas94z's Avatar
i was assuming that he built the 383 with the appropriate rings. agreed a dual stage would be nice set up. i would die for a duel stage from nitrous outlet. drool.
texas94z is offline
Old 12-28-2007, 09:09 AM
rskrause's Avatar
I'd worry about the pistons.
Rich
rskrause is offline
Old 12-28-2007, 09:41 AM
LT1TONY's Avatar
Originally Posted by kline454
Im running a 383 11.7cr cc306 le2 heads,srp forged pistions, egale H-beam rods and 4340 forged crank. 2bolt block with arp studs, Last year i was spraying a 200shot i want more but dont want to break the block how much more can i go??
Spray a 250 shot Kyle. Make sure you run good fuel, pull timing and check the colder plugs.
LT1TONY is offline
Old 12-28-2007, 02:02 PM
LT1TONY's Avatar
Hey Kyle,
Better yet, I think you should spray a 400 shot so you can keep up.
Just joking around.
Give me a call sometime to catch up.
Later,
Tony
LT1TONY is offline
Old 12-30-2007, 02:40 AM
slomarao's Avatar
if the motor wasnt build for juice i would stay where your at. Maybe 225, tuning is key though.
slomarao is offline
Old 12-30-2007, 09:34 AM
missetti's Avatar
My engine was built for nitrous, but also to pass Ca. smog. I run high tens, low elevens on a 200 shot, thru stock cats. I have the hot cam with .525 lift. Lots of other stuff. I tried going with a bigger shot, and didn't notice a significent difference. Figured that with the limited lift and cam that I have, only so much can get injested into the motor. So I'd say go up a little at a time, until you see where it begins to not make a difference. By the way, nice 60 foot.
missetti is offline
Old 01-02-2008, 09:41 PM
97SS0594's Avatar
i spray a 300 shot on my 355 i have countless bottles through it, motor is solid still.
97SS0594 is offline
Old 01-04-2008, 07:33 PM
nxfirebird's Avatar
if your motor will lives or dies on a big hit depends not so much on your parts but your tuning ability.
the standard ring height SRP pistions will take more then you can imagine ... if you have your tune on, if your don't even a nitrous pistion will break.
i ran a 325 shot on a cast crank, 2 bolt 350, with ARP fitted stock reconditioned rods and SRP pistions for years, but i've been doing this for a day or two.
you have to ask yourself if you think you know enough about nitrous to do it or not, and even if not, there's only one way to learn!
nxfirebird is offline
Old 02-05-2008, 03:43 PM
kline454's Avatar
Originally Posted by LT1TONY
Hey Kyle,
Just joking around.
Later,
Tony
400shot sounds good to me.lol well i think im stepping up to a 125
kline454 is offline
Old 02-05-2008, 03:46 PM
LT1TONY's Avatar
400shot sounds good to me.lol well i think im stepping up to a 250.
I thought you forgot about this post.
250 sounds good and it should run real good!
Now get the tranny bugs worked out.
LT1TONY is offline
Quick Reply: what size shot?? yes again.
