Shock install
Old Dec 22, 2007 | 09:52 PM
Black 97 SS's Avatar
Shock install
I have bilsteins on my car that i put on about a year ago. I think I messed up someting with the big washer thing, not sure what its called. The directions were kinda crappy. Anyway I want to fix it does anyone have a picture or could you tell me in what order everything gets installed in. I looked at alot of threads couldent find any help. Thanks in advance!
1997 Camaro SS #1039 M6
LE1, CC306, Pacesetter Long tubes, TTL exhaust, No Emissions, Under Drive Pulleys, Mad Z28 Tune, 4:10’s, Level II Suspension, BFG KDW’s. best time (bolt-on only) 13.3 @ 105mph, 94 F
Old Dec 24, 2007 | 12:52 AM
slomarao's Avatar
umm its pretty cut and dry, you should clearly see if something doesnt look right.
Old Dec 24, 2007 | 01:31 PM
OBE1 95Z28's Avatar
Injuneer has a good write-up here: http://members.aol.com/InjuneerZZ/HALEibch.htm
Just ignore the details regarding the HAL specific changes.
Old Dec 26, 2007 | 12:25 PM
I'm not familiar with the specifics of the Bilsteins. Are you talking about the front or rear shocks? What "big washer thing"? Where is it located (or supposed to be located)?
Old Dec 26, 2007 | 04:13 PM
shocks
They are the Front, one washer came with each shock, its about 1.5 " end to end and about a 1/4" is bent over on the sides. Its really hard to describe. I will take a pic and post it.
Old Dec 27, 2007 | 12:01 AM
The stock shock has a big washer that sits on top of the shock, to act as the impact surface for the jounce bumper built into the stock dust cover. Upper right in this photo....
Old Dec 27, 2007 | 06:12 PM
Thats it, thanks Injuneer. So the washer goes on the shock than the dust cover goes over that? The Bilsteins also have a dust cover, I cant remember if the Bilsteins came with the washer or if I stole them off my old shocks. I will probally be able to tell soons I disassemble the shock from the spring. Maybe it doesent even need that washer. Im gonna tear it apart Saturday I will let you know. Thanks again
Nov 18, 2023 07:21 PM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
