Cleaning master cylinder reservoir
Old Dec 19, 2007 | 05:38 PM
MadaSnik84's Avatar
I've got my master cylinder reservoir off to clean all the black residue out of it. I thought I could get in through the holes in the bottom until I realized how small they were when I got the reservoir off.
Any suggestions on how to get this cleaned out would be appreciated - specifically the chambers at the front and rear that you can't get at through the fill hole due to the baffles. I see in my Chevrolet manual it says to use denatured alcohol.
The thought of using brake cleaner crossed my mind, but I didn't know if that would damage the plastic or not.
Old Dec 19, 2007 | 05:54 PM
greenmachinedriver's Avatar
use breake cleaner it will not hurt the plastic. brake cleaner is pretty much alcahol and water. it would be really bad if gm made brake parts that would be hurt by brake cleaner. ha ha
Rod Bender
Nov 7, 2023 02:30 PM
Rod Bender
May 16, 2015 02:16 PM
Ringmaster72
Mar 19, 2015 03:32 PM
94bird
Aug 5, 2002 09:33 PM
