Original Fuel Line
Old Dec 9, 2002 | 01:59 PM
racr4jc's Avatar
Original Fuel Line
To what hp range would you guys trust the original fuel line in your first gen camaro?
Old Dec 9, 2002 | 10:41 PM
orange68's Avatar
dont trust it for any non stocker. track wont like it eather, id suggest a nice new line with at least braided covers to protect from getting cut or melted
Old Dec 9, 2002 | 11:05 PM
camaro_dave's Avatar
if its for that TT camaro you have in the sig i would run at least a 10AN braided hose. i run 2 10 AN braided hoses out of the fuel cell into one 10 then 10 out of the fuel pump then to the rugulator then a 8 to both sides of the carb. at least run braided hose even if its smaller but i wouldn't go smaller cause your gonna be using a lot of fuel.
Old Dec 10, 2002 | 04:42 PM
racr4jc's Avatar
Would you suggest using the orignal tank and just modifying it with a bigger pickup and lines? Should I have a sump welded on? Or should I drop it and install a fuel cell?
Old Dec 10, 2002 | 08:24 PM
orange68's Avatar
a nice trunk mounted cell would probably be easyer and less expencive then modifing your current tank and its cool too! if you are going -an's up front, you should get big enough lines to feed those as well. have any pics of your car? id like to see what youre working on
Old Dec 10, 2002 | 10:18 PM
i would get i fuel cell. already has the sump end everything and they look cool. i would run all an fittings not just up front, might cost a little more (lot more) but its worth it.
*Emilia*
May 13, 2015 09:05 AM
Jazsun
Dec 29, 2014 12:14 PM
Ryabut98
Sep 3, 2002 11:45 PM
