Tune to make shifts less firm?
Old Nov 30, 2007 | 12:47 AM
mrmint69's Avatar
I have a shift kit in the car right now that came with it when i bought it. It is set so that when the car shifts i loose traction real bad between 1st and 2nd. I don't know much about transmissions so i am looking for a fix without opening it up. I was wondering if a mail order tune could help with my problem and make the shift less aggressive? I have seen that you can make the shift firmer so maybe it can go the other way also. The more horsepower i keep adding to my car, the worse the problem gets.
Old Nov 30, 2007 | 06:52 AM
shoebox's Avatar
In normal driving the transmission shifts relatively softly. If your shift kit makes this too hard, I don't think any reprogramming is going to help. You would need to remove or modify the shift kit.
Old Nov 30, 2007 | 02:42 PM
mrmint69's Avatar
I called a transmission shop and he said they probably drilled holes and put in stiffer springs so they would have to be replaced with new parts. He was guessing $400-$500 total. What do you think of his estimate and solution?
Old Nov 30, 2007 | 04:11 PM
shoebox's Avatar
Unless you know exactly what was done to it, you won't know what it will take to put it back to normal.
Old Dec 6, 2007 | 09:43 PM
VinceTrifecta's Avatar
Commanding less line pressure should soften the shifts, in theory. It depends what the shift kit did to the trans though.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
InfernalVortex
Jan 17, 2015 09:35 AM
97SSdude
Dec 31, 2014 07:43 PM
