rear end qs
Old Nov 27, 2007 | 07:19 PM
PARTSMAN8484's Avatar
rear end qs
can you make a 96 rear end which has the abs connector on top of the pumpkin work with a 01 car which has the connection at the wheels ????
Old Nov 27, 2007 | 10:04 PM
rskrause's Avatar
If you don't care about ABS, it's easy.
Rich
Old Nov 27, 2007 | 10:13 PM
there is no way to wire up the abs to make it work ?
Old Nov 28, 2007 | 08:41 AM
AL SS590 M6's Avatar
The only way to make a 3 channel rear work in a 4 channel car is to use axles, backing plates, and sensors from a 4 channel rear. Swap the backing plates and axles with the reluctor rings onto your 3 channel rear and it's plug and play. Just ignore the sensor on the pig.
Old Nov 28, 2007 | 09:20 AM
Capn Pete's Avatar
If you're putting the 3-channel diff (with the single plug on top) into a car with 4-channel (sensors at the axles) that's much easier since you can do as Al said and just use all the 4-channel hardware (axles, brake backing plates, sensors, etc.).
HOWEVER, if you have a 3-channel CAR, and want to put in a 4-channel DIFF, not so easy ... then you'd have to screw around with pulling the reluctor ring off the carrier, drilling the hole in the top of the pumpkin for the sensor ..... I dunno, for how many of these diffs are out there, then it's probably easier just to locate the correct one in the first place!
But to put a 3-channel diff into the 4-channel car? ..... not so bad!
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
