Nitrous intercooler spray
Old Nov 18, 2007 | 08:16 PM
detroit1994z28's Avatar
I have a 94 z28 with a STS kit. I'm currently running meth injection. Next summer I plan to run a fmic. I wanted to run both intercooler and meth. Also I was thinking about the nitrous intercooler spray. For a triple cooling effect. Would that be overkill or could I use all 3 sources??.
Old Nov 18, 2007 | 09:16 PM
LT1-TA's Avatar
waste of exspensive gas that should be sprayed into a motor....
meth injection is more than enough
Old Nov 19, 2007 | 01:49 AM
CALL911's Avatar
FMIC for cars under 9#'s of boost should be enough on its own. Most very high boost levels can be kept away from detonation with methanol injection alone. If you are using both (which I am as well) then you will be well covered, and the nitrous will not be needed to cool your IAT's further, assuming you get the appropriate methanol injection nozzle and setup for your specific application.
Old Nov 19, 2007 | 03:19 AM
Sparkz28ss's Avatar
I use it... but I use co2 as its half the price
....just some dry nozzles on brackets and a cheater noid and a different fitting on the bottle.Only took a few beers to come up with and get it in the car and working.
It works well for me..... it can get a little warm here so I see no harm in dropping the IAT temps
Old Nov 19, 2007 | 03:35 PM
BlackMagicC5's Avatar
I agree. Meth is very effective.
Jeff1904
Jun 5, 2016 05:00 PM
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
damnyankee36
Sep 9, 2015 07:06 PM
