Cat going bad affecting gas mileage?
Old Nov 18, 2007 | 05:25 PM
Skywise's Avatar
I've got a '97 Z28 Camaro with 172,000+ miles on it. For the past three weeks, about once a week I'm getting an SES code being thrown for the drivers side catalytic converter efficiency being bad (P0420). So I've been grudgingly acknowledging the code and clearing it until I can get enough cash together for a replacement. (the passenger side cat was replaced last year)
For about the past two months, my gas mileage has dropped from an avg of 20mpg to 18 over the last two months. Would the cat going bad cause this or would this be some other problem?
The engine is running fine otherwise and no other codes are being thrown.
Old Nov 18, 2007 | 07:05 PM
greenmachinedriver's Avatar
it definately could be the cat but you wont know for shure untill after you replace it. there are a million things that can adversely affect mileage. good luck.
Old Nov 18, 2007 | 08:42 PM
Only if its not making efficiency because it is plugging up and reducing exhaust flow. If the cat is still free flowing, it isn't going to affect gas mileage.
Old Nov 19, 2007 | 07:22 PM
Red89GTA's Avatar
Also remember that (depending on where you live) we have changed over to winter blend gas, which gets lower mpg then summer. So, it's possible your bad cat is causing a lower mpg average, but not for sure.
Old Dec 8, 2007 | 10:13 PM
Dwaynez28's Avatar
I have the same code, comes and goes, but my car also burns real rich--What i have read, you have to find the cause of why the cat is going bad or you have a real good chance of your new one going bad also. I think this will help--I think-- Dwayne http://aa1car.com/library/converter.htm
Old Dec 11, 2007 | 12:40 PM
Skywise's Avatar
Red89GTA: Thanks for reminding me... I had a similar drop last year and had forgotten about the change. (Though not this bad so its probably a combination)
hmm... I'm burning oil for sure. Had a screwed up ignition system last year (opti) that clobbered the passenger cat and may still have a problem with the spark plug wires/distributor (going too fast through a water puddle makes the engine hiccup...)
It's probably faster to figure out what ISN'T the problem Thanks for that, though!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
kksi
Mar 21, 2015 09:03 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
