what rims are these?
Old Nov 14, 2007 | 06:52 PM
reamo04's Avatar
his fron'ts do not look like they stick out like a prostar
interested in knowing, caue i'd like to pick a set up, cause i don't want my fronts to stick out
Old Nov 15, 2007 | 10:00 AM
Looks like they may be the Bogarts.
Old Nov 15, 2007 | 11:15 AM
Z-RATED94's Avatar
I think Fred is right. I purchased the welded RTs for that reason. The fronts don't stick out, and the backs tuck in nicely. If you have LS1 front brakes though, it moves the wheel out slightly. I don't and do not plan on going with those brakes.
Plus, with these wheels there is no grinding, spacers, using a hammer, etc. I did trim the bump stops to clear the tire though, it rubs slightly when the car is jacked up. But other wheels are worse in this respect. Just be ready to lay out some extra money for these benefits.
Old Nov 15, 2007 | 12:38 PM
reamo04's Avatar
dang, so those are out of the question since the car will see street duty, and bogarts do not like that do they?
Old Nov 15, 2007 | 12:44 PM
reamo04's Avatar
wait, look at the front rims on the car i posted, where the bogarts on the "star" part, slant inwards, the ones i posted stay straight, so i believe they are something else
Old Nov 15, 2007 | 12:49 PM
reamo04's Avatar
well guys, after some looking around, these look a little closer to what i posted
http://store.summitracing.com/partde...5&autoview=sku
would 1.75" backspace on a 4" rim work, or would those stick out?
Old Nov 15, 2007 | 05:41 PM
The Bogarts are the "SS" model and completely "flat" on the center section (spokes). The wheels you linked on Summit are the old Weld Pro-Star XL wheels. They have a curved surface on the spokes.
Old Nov 15, 2007 | 05:47 PM
reamo04's Avatar
alright, thanks injuneer. Since I dont want bogarts since the car will bes treet driven, would those "Summit Star" rims work for the 4" rim with a 1.75" backspacing?
Old Nov 15, 2007 | 10:56 PM
I have a 3.5" wheel with 1.75" BS. With the 5/16" spacer, it "sticks out". If you had a 4" wide wheel with a 1.75" BS, and no spacer, your wheel would stick out 0.18" more than mine.
Old Nov 16, 2007 | 10:20 AM
Z-RATED94's Avatar
Should you drive them on the street? No. But you know how it goes, do as I say, not as I do! Very carefully though (turns), and this is not my DD. So far 1k and no problems.
Old Nov 18, 2007 | 03:04 PM
JGKadell's Avatar
Those are Bogart's but not the SS. It is the DOS, Drag on Star
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
Formula Steve
Sep 19, 2015 08:48 PM
rvonsternberg
Sep 14, 2015 11:58 AM
scottcba1
Sep 8, 2015 09:52 AM
