heater core flush
Old Nov 12, 2007 | 06:06 PM
ttop1986's Avatar
heater core flush
I tried flushing my heater core today by taking off the 2 hoses from the waterpump. It would flush one way pretty well, but not the other way. I'm asuming theres some sort of 1 way valve in there somewhere? Damn, I still have no heat. At least I did the TB bypass.
Are there any write ups online for doing the heater core flush?
Thanks
Old Nov 12, 2007 | 06:21 PM
Mtxz453's Avatar
how did you flush the core? i hooked up a garden hose to the heater inlet hose and a bunch of black gunk came out the outlet hose, after running it for 5 minutes i put coolant back in and had red hot heat.
Old Nov 12, 2007 | 06:27 PM
DIYAR21's Avatar
i just got done like 10 mins ago. i put the garden hose to outlet hose (the one of top of the waterpump) and water came out of inlet hose pretty well and clear. I put them back and added some coolant to radiator and heat started to work but still not HOT HOT yet but it flows warm now. Howveer i didnt try to put the hose in inlet and try to fflush away from outlet. Maybe i should try that.
Old Nov 12, 2007 | 09:39 PM
ttop1986's Avatar
I tried doing it both ways. On the inlet and the outlet. The inlet was the one that would actually flow though. The outlet hose would just build up pressure and nothing would come out the other end, so that's why I figured it had a one way valve. I probably just didn't leave it going through long enough. It started to get dark and I had to get it back together.
Old Nov 13, 2007 | 10:07 AM
RE AND CHERYL's Avatar
The is no check vale, you have a blockage in there somewhere.
Re'
Old Nov 13, 2007 | 09:21 PM
ttop1986's Avatar
Re'
thanks! Looks like I will have to try it again sometime.
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Quickss96
Jan 29, 2016 05:56 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
ducttape1975
Jul 10, 2015 06:29 PM
