rim problems
Old Nov 12, 2007 | 11:27 AM
yourmom's Avatar
rim problems
if you get 18's does it effect your transmission, i know it changes your speedo but does it promote premature tranny failure?
Old Nov 12, 2007 | 12:41 PM
96 Z 28's Avatar
Actaully if you get the correct Sized Tire for the rim your Speedo will still be accurate, and I would think there should be no additional wear on the Tranny. Basically if you match the outside diamter of the rim / tire combination to the factory the rotational forces are exactly the same. Just a bigger Rim and lower profile tire......
LD Kirk
Apr 30, 2015 08:54 AM
mschmidt33
Mar 15, 2015 07:20 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Kato
Jan 26, 2015 09:21 PM
siguy
Nov 27, 2014 10:07 AM
