Output Driver Module Fault
Old Nov 4, 2007 | 11:07 PM
97'Z-28's Avatar
Exclamation Output Driver Module Fault
hello, Serg here, I recently bought a 1995 camaro z28 with the T-56 and I hooked up a scan tool just to see what it would read and it said "Output Driver Module Fault" and also said DTC#29. The car runs normal and I would just like to know what a ODM is and what could be wrong with my car.
Any help would be great. Thanks
Old Nov 5, 2007 | 06:47 AM
shoebox's Avatar
Click the DTC link in my sig for "real" code defiinitions pertaining to the f-body and not generic ones you see on the scanner. Code 29 is for the AIR pump. Check the fuse.
Old Nov 5, 2007 | 08:00 PM
97'Z-28's Avatar
Thanks, I checked the fuse and it was bad, I replaced it,erased the codes, and scanned it again and it still shows the same thing: Output Driver Module Fault I have no idea what that means. thanks again for helping me out
Old Nov 5, 2007 | 10:55 PM
shoebox's Avatar
You don't need to know that that means, because it is not the right definition. Again, look at the code descriptions on my Tech Page. Check the fuse again, maybe it blew again-meaning the AIR pump is probably seized up.
Old Nov 7, 2007 | 09:54 PM
97'Z-28's Avatar
The fuse is still fine, I scanned it with an other scanner, thinking the first one was acting up, It still read Output Driver Module Fault but this time it also said EAS circuit
Old Nov 7, 2007 | 10:23 PM
shoebox's Avatar
One more time...read the code number from the scanner and use my list. Quit looking at the generic description that is on the read out of the scanner.
Old Nov 8, 2007 | 10:07 AM
97'Z-28's Avatar
OK, I got it, turns out it was a small corrosion problem in the connector. :-)) thanks 4 the help shoebox!
Old Nov 8, 2007 | 10:08 AM
I would have given up about two posts before this one.....
Old Nov 8, 2007 | 04:59 PM
shoebox's Avatar
Lol, it's all good. At least he was finally able to resolve the issue and did acknowledge the help.
timmy39120
May 8, 2015 11:41 AM
markzzzz
May 8, 2015 09:21 AM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
dluna333
15
Mar 13, 2015 12:30 PM
