pacesetter lt install
Old Oct 14, 2007 | 12:30 PM
northdakota93z28's Avatar
Angry pacesetter lt install
i broke what i think is the oil pressure sender, i got the headers in and on but i dont think that the oil sender will fit in, it is so long and if it does fit in it will be right agains the header that will melt that, i am wondering what to do, i will order a new on on monday but i dont think it will work, any input would be great thanks
Old Oct 14, 2007 | 12:46 PM
did a search i will put a L in there so that the sensor is right next to the block
Old Oct 14, 2007 | 12:54 PM
camarozz95's Avatar
Did the same exact thing to mine I broke the thing and was like ****....bought a new one and was like uhhh hows this going to fit in here, but it did its still pretty close the the header but haven't had a problem I put some heat wrap tape on the sender, been almost a year no problems.
Old Oct 14, 2007 | 03:40 PM
Pyrodawg's Avatar
mine broke when we were doing my header install... luckily i had a gm master tech helping me haha... he got a 90* pipe bend and put it in the hole with it pointing towards the front of the motor and made it so the sending unit is also going towards the front of the motor instead of straight out towards the header
Old Oct 14, 2007 | 05:08 PM
that is what i am going to do,
Old Oct 14, 2007 | 05:12 PM
my wires 5 and 6 are very close to hitting the header 5 is touching so i am wondering what my options is anyone running stock wires and if so what could i but inbetween there to help if i fired it up now it would burn 5 for sure.
Old Oct 14, 2007 | 05:15 PM
dangalla's Avatar
i think what you broke is the coolant temp sensor
Old Oct 14, 2007 | 05:42 PM
no its oil, does anyone run stock wires and lts?
Old Oct 14, 2007 | 06:03 PM
camarozz95's Avatar
I did for about 8 months until i switched to my taylor OTVC setup I never burnt a wire the only reason I changed was because I had this kit laying around and had never gotten the chance to put them on.
Old Oct 14, 2007 | 07:24 PM
how close was your closest wire? 1/8 inch?
Old Oct 14, 2007 | 08:03 PM
Ok4thGen's Avatar
There is absolutly no reason to have to add a elbow on the sensor to make it work with your pacesetters, just replace it as normal it will be fine.
Old Oct 14, 2007 | 08:32 PM
Pyrodawg's Avatar
no need but i wanted it done for added insurance... not like it hurts anything
Old Oct 14, 2007 | 08:42 PM
Jeff H's Avatar
I had to tie off a couple of wires to make sure they didn't hit the header tubes on my old 96 SS. I also put some heat wrap around one wire just in case. Take your time and do it right so you don't have to replace anything later on.
Old Oct 14, 2007 | 10:00 PM
cool i will, my hands r sore, and the install was hard but i still love my car
Old Oct 14, 2007 | 11:42 PM
JoeliusZ28's Avatar
i didnt have that problem with the sender maybe its an issue on earlier cars? and if the boots are touching you will be ok. i started mine up expecting to burn multiple wires immediately and it never happened, even a year and a half later. when you replace them though you will want to do an over the valve cover routing.
