Well i [messed] up again.....but how?
Old Oct 11, 2007 | 01:44 PM
User56898's Avatar
Well i [messed] up again.....but how? UPDATE
how could this have happened:
waste of a good trans
EDIT/UPDATE
so my buddy calls me up after finally getting around to taking the trans apart. He told me 300 for all parts and to swap everything and he was going to put a shift kit and a few other things in for me. He said that the trans is worth about 10 bucks in scrap metal....I laughed....he didn't
he asked why i didn't tell him the reverse didn't work. I said it did and he was shocked. he said everything was F**ed beyond repair inside.....
The new total to fix it is 850. Thats from a friend. Basicly i need a new trans all together.....
so should i fix it or get a new trans? 850 to fix the TH350 seems high and a waste. I plan on having around 650-700hp in a few years (at 510/524 now)
i really want to do a manual conversion or a overdrive auto swap.......
BRIGHTSIDE
w/o me screwing up the housing, i would have never known it was so bad and would have installed it jsut to have it blow. Then i would have to take it all apart again......
Old Oct 11, 2007 | 03:08 PM
User56898's Avatar
sorry mods....
Old Oct 11, 2007 | 07:45 PM
Performabuilt's Avatar
Supporting Vendor
Man that suck but honstly to do that you about had to have missed indexing the converter properly thats the only way I could see that type of force could be applied. Sucks though
Old Oct 12, 2007 | 07:19 AM
Bersaglieri's Avatar
Explain what you mean by indexing the converter.
-Dustin-
Old Oct 12, 2007 | 08:26 AM
Supporting Vendor
The converter has two slots in it that match the two slots in the pump . If they are not in each other the converter will wedge between the pump gears and the flexplate and when you titen it can either break the pump or in your case the case of the trans.
Old Oct 12, 2007 | 08:30 AM
dangalla's Avatar
yup, i did that once
learned real quick to make sure the converter is all the way in
Old Oct 12, 2007 | 09:21 AM
User56898's Avatar
cant be it.... the converter was fully in........
Old Oct 12, 2007 | 11:05 AM
mdacton's Avatar
http://www.jegs.com/webapp/wcs/store...48597_-1_10533
Old Oct 12, 2007 | 11:39 AM
User56898's Avatar
? how does that work, the trans is one piece..... the bell housing doesn't unbolt
thanks a lot for the help and taking the time to find that on jegs though
i may be able to get a used POS th350 through work for dirt cheap and have someone change everything over
Old Oct 12, 2007 | 12:57 PM
jay_lt4's Avatar
you take a cut-off wheel on a grinder and cut your bell off the trans, then the new bell bolts to your trans using longer bolts for the front pump assy
Old Oct 12, 2007 | 04:21 PM
User56898's Avatar
OMG I AM RETARDED
wow i am 110X more pissed off right now
so i came home from work and decided to take a good look to find out what happened....
i measured everything tosee if there was any difference from the old motor/trans set up to the new....
everything was right on the money
so i say to myself "wtf is wrong here"
sure enough the converter wasn't all the way in. i guess in my excitement to get the motor and trans in the car for the first time made me miss it. when i said i felt it slid in and then engage this is what really happened....
filled it with fluid and put it on whie the trans was on a table...
the first feeling of it going in was really the bottom of the converter pushig against the table.
the second feeling was it going in halfway
spun it a few times but it never whent fully in
came home and turned it 1/4 turn and sure enough it whent in another 3 inches
i was hesitant about posting this due to this proving how stupid i can be, but wtf live and lern
Old Oct 12, 2007 | 04:22 PM
User56898's Avatar
so i got two options
spend 300-400 on a new housing and paying a buddy to change everything over or....
do what you posted
What would you guys do?
Old Oct 12, 2007 | 05:08 PM
Supporting Vendor
You could probably buy a case for 100 dollars or so and find someone to swap the guts for about the same or a little more , Thats what I would do , And dont feel stupid many people do that in fact its the most comon mistakeI hear about after a new install and it wont move. So your not along and you have learned so not a total loss.
do what you posted
Old Oct 12, 2007 | 05:17 PM
User56898's Avatar
i just got a call back
325 for:
new case
transfer all the parts
all new seals
new filter, gaskets etc
shift kit
and any little things broken he said he will take care of
the part to do the above swap is about 250 so i figure this is a better idea....
lol the guys at work wanna "help me" once its all fixed. they said they want to see a bellhousing blow apart again..... smart asses lol
Old Oct 12, 2007 | 06:15 PM
Supporting Vendor
Sounds reasonable and like the best choice. Holle if you need anything ,
325 for:
new case
all new seals
shift kit
