5 speed interchange
Old Oct 9, 2007 | 06:46 PM
nevermind65's Avatar
5 speed interchange
I have a 350 in my car with a Borg Warner T-10 behind it. It has a blowproof bellhousing with a hydraulic clutch set-up. I would like to install a 5-speed to get the O/D. Does anybody know which trans might bolt up to this bellhousing and be able to about 400-450 hp?
Thanks in advance.
Old Oct 9, 2007 | 07:44 PM
thesource2004's Avatar
You have two choices that come to mind right off hand .
One would be a built T5 using Astro Performance A5 gears and the other would be a Tremec 600 (chevy version) .
Both are expensive but both should bolt up to your bellhousing . Your other option is a T56 unit with an adapter to bolt up to the bell housing as well .
njspder
Middle Atlantic
Mar 5, 2015 05:39 AM
Chris Anderson
Jan 27, 2015 08:30 AM
sdn1997rs
Dec 30, 2014 08:30 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
