True duals over BOTH sides of the axle?
Old Oct 6, 2007 | 03:06 PM
9formula4's Avatar
Can it be done? I have seen pics of one that ahs it done but they cut the upper PHB and ran it between the bars. Now I would think it would get crushed upon impact of a bump or hole in the road but thats just my two cents.
Anyone want to shed some light on this for me?
Old Oct 7, 2007 | 08:19 PM
Tricked-Out-Toy's Avatar
Yup you can do it. ive got a 9" with 3" duals over both sides. the driver side I ovaled a little bit were the panhard comes up. I didnt relocate the panhard but if you did you might be able to get away with not "ovaling" the pipe.
Old Oct 9, 2007 | 07:49 AM
Originally Posted by Z28Roxy
Why do you want to go over both sides? If it's just to say you did it, that's cool, but you can put both over the passenger side. Mine are that way, I did not relocate the PHR brace, and they don't rub or rattle.
I did it because I didnt think I could get two 3" pipes through the area where the stock exhaust came over the axle. as it was I had a hard enough time just getting the one 3" to work and still be able to take it out without dropping the axle. I think it is a little better performing since theres less bends and more of a straight shot back.
Old Oct 9, 2007 | 06:35 PM
Could well be.
I fit dual 2.5" over the passenger side though, like I said. BMR also makes a kit to relocate the panhard brace so you can run dual 3" over the passenger side.
Just curious: why did you go with dual 3"? That's a lot of exhaust, even dual 2.5" is more than single 3.5"
I did dual 3'scause i could.... plus it cost me the same to do 3's as it would have to do 2.5's. plus i had planned on dual twin turbos and dual 3's would have been perfect for that.
QuickSilver02
Apr 7, 2015 11:12 AM
alphaauto
Jan 22, 2015 08:02 PM
RedLineRev
Jan 23, 2003 03:51 PM
guionM
9
Aug 29, 2002 01:48 PM
