retarding timing with nitrous
Old Oct 1, 2007 | 02:06 PM
96LT1TX's Avatar
What do you guys use to retard the timing for nitrous? I have tunercat, but have yet to learn to use it. I still have 5deg of knock that is mysteriously only while on the gas or at idle, so I am trying to fix that of course first. I have talked to some people and what I am hearing is to straight pull the timing in the tune instead of using an ignition box setup? Any one have luck w/ an ignition box or the tunercat?
thanks
Old Oct 1, 2007 | 02:53 PM
Ray@NitroDaves's Avatar
I am using a MSD Digital 6 to retard the timing on my 94....used to pull 2-3* when it was H/C/150shot and I am now pulling 8* on the current 200 shot...no issues as of yet.
Old Oct 2, 2007 | 09:25 AM
Moshbmx1's Avatar
With pulling it with a tune you will be pulling it all the time and the car wont run as well NA. With a box you will just be retarding when you are on spray. IMO this is the definate way to go. I am running the Mallory 685 ignition box and pulling 5ish i believe
Old Oct 2, 2007 | 01:21 PM
96LT1TX's Avatar
Yes, it would be pulling it all the time, if I didn't have my laptop with me. Since I have my laptop I can run to the track on my normal tune, and do nothing to the tune except change the timing (-whatever degrees for 100shot, maybe 2deg?) and then that is my nitrous tune for at the track. This is what I was thinking about... still not sure.
Old Oct 2, 2007 | 04:45 PM
Moshbmx1's Avatar
Until you get the urge to show the rice whats what on the street and you have the street tune in there
Old Oct 2, 2007 | 08:24 PM
LT-x7's Avatar
Or when you want to make a pass N/A and run slower because your on the nitrous tune.
Ignition box is the way to go, if your bottles full and warm your ALWAYS ready.
Old Oct 4, 2007 | 01:00 PM
96LT1TX's Avatar
Thanks guys for all the info, it is looking like the ignition box path will prevail. Very good points. How many degrees again? I have heard 2-3deg for every 50hp pill? So 5deg for 100shot?
Old Oct 4, 2007 | 01:50 PM
every car will be different but 1-2 per 50 is the normal starting point....I am pulling 8* for a 200
Old Oct 4, 2007 | 02:19 PM
rickyzZ28's Avatar
How much can you pull with the Mallory 685? I was under the impression that 4 was the most this box would pull. Is this wrong, I hope so, then I will throw in the 150 jets.
Old Oct 4, 2007 | 06:26 PM
69z-28's Avatar
mallory 685 here. i love the box its badass.
my dynotuner was aware i would be spraying, after tuning the car in, he pulled 4 degrees and there was no drop in n/a performance, so he told me not to pull any more timing, i still pull 2 degrees with a 125 shot through the mallory and so far its awesome.
Old Oct 5, 2007 | 12:29 AM
Jditlfm's Avatar
I can pull up to 15 degrees with my mallory box and if you wire it right it will only pull timing when the nitrous is activated. I love my mallory box.
Old Oct 5, 2007 | 12:05 PM
69z-28's Avatar
mhmmmm.
Old Oct 5, 2007 | 04:49 PM
2000GTP's Avatar
I'm using the Mallory box as well, another handy feature it comes with is also a window switch. Its a pretty good bang for the buck.
Old Jan 2, 2008 | 08:05 PM
wyldcdn's Avatar
i've noticed with the msd boxes there are variations of msd 6a's
what exact version? looking to run a 100 shot
Old Jan 2, 2008 | 08:14 PM
evanbrendel's Avatar
dont kno if they make one for a lt car but i use a msd timing twister only takes timing out when spraying.
