4:10's.. 150 shot?
Old Sep 25, 2007 | 08:17 PM
BlkZ28Kreepn's Avatar
4:10's.. 150 shot?
sorry if this doesnt belong in this section.
what are your thoughts?
anyone here running 4:10's with 150?
car is automatic 94 z28 stock rearend.
im sure the rear-end is on counted days after that.
Old Sep 25, 2007 | 08:23 PM
endobong's Avatar
aslong as you dont dead hook your be alright for awhile
Old Sep 25, 2007 | 09:41 PM
im sure with slicks i'll be done,but as far as running drag radials,nitto's or bfgs?
Old Sep 25, 2007 | 09:43 PM
northdakota93z28's Avatar
do it, do you have a stock stall if so you r not spraying off the line so i would not be worried at all.
Old Sep 25, 2007 | 10:46 PM
the car has a 2200 stall, i have 3:42's right now.i'll must likely be running on 295/35/18's bfg drag radials.
Old Sep 25, 2007 | 11:28 PM
sn8ke eatr's Avatar
it would be safer if you stuck with the 342s, i think itll last for a while but its only speeding up the inevidable..
Old Sep 25, 2007 | 11:40 PM
waterbug1999's Avatar
Hope you dont do much highway driving.
Old Sep 26, 2007 | 01:06 AM
not really, its a weekend car..got a civic for daily driving..
Old Sep 26, 2007 | 10:05 AM
Ray@NitroDaves's Avatar
the bigger issue is going to be rpm related ....I ran 4.10's in a T56 car and was turning 6500+ running 120mph traps...switched to a 4L60 and was only able to get 115 out of it at the same RPM.
Double check the RPM/Speeds you are planning on running.
Old Sep 26, 2007 | 10:35 AM
buzz12586's Avatar
Check out this site. http://www.f-body.org/gears/
I think you will more than likely run out of gear.
Old Sep 26, 2007 | 01:35 PM
thanks for the help, would i really feel a difference going from 3:42's to 373's?...also the nitrous wont always be in use for any race, i just have it for back up..thats the reason why im leaning 4:10's..
Old Sep 26, 2007 | 05:00 PM
mliers's Avatar
I've got 4.10s with a stock 10 bolt, a 3200 stall, 150 shot, 325/15/50 MT DRs....previous owner trapped at 120 on the 1/4 mile..not sure where he was RPM wise. I think the taller tire helps a little with the 4.10s. We have a 1/8th mile here so no worries about running out of gear.
Old Sep 26, 2007 | 05:35 PM
correct you are on a 28" tire...this is what is giving you the extra MPH.
I am running a 27" tire and 3.73's...that shoult net me ~140mph at 67-7000 depending on convertor slip
Old Sep 26, 2007 | 09:26 PM
LT-x7's Avatar
Is your trans stock?
You'll run out of gear if you don't use overdrive. Nothing wrong with that if you have faith in your tranny.
Old Sep 26, 2007 | 10:17 PM
mrr23's Avatar
been there, did it. had to shift into 4th about 60-70 feet before the traps. this was on 26" tall tires. you would need at least a 28" tall tire to help that. 3.73 much better
