Any A/C experts out there?
Old Sep 20, 2007 | 07:30 PM
Dtimekw's Avatar
My A/C seems to work fine when I first start the engine. After a while, the compressor stops turning. One of two things seem to cause this. I have notice that under a high rev condition (1st, 2nd gears revved up) the A/C stops working. Another thing I noticed today, I first started the engine, A/C compressor kicked on. I shut it off and drove around. After the car has warmed up and was driven for a good 30 mins, the compressor wouldn't kick in. I live in S. Fla, air temp was about 92 today. System was just charged. When the compressor does kick in, it is pretty cold. Any ideas? I am dying down here.........
Old Sep 20, 2007 | 07:54 PM
RedWS6TA's Avatar
does it freeze up? if so it could be the cycle switch that is not working properly
Old Sep 20, 2007 | 08:06 PM
n2ceptor's Avatar
If you are sure the freon level is correct(IE checked with gauges), check the clutch cycling switch..... It might be bad or loose conection????
Old Sep 20, 2007 | 08:16 PM
MeanGreen97Z's Avatar
Was it working better before the recharge?
Old Sep 20, 2007 | 08:21 PM
Dtimekw's Avatar
It was recharged after the engine swap. Had the same problem before though. What is a cycle switch? Where is it? What does it do? At this point, I am ready to replace all sensors and switches. I just don't know where/how many there are.....
Old Sep 20, 2007 | 09:44 PM
n2ceptor's Avatar
Courtesy of Shoebox..
Old Sep 21, 2007 | 06:14 AM
Dtimekw's Avatar
I'll check it out, thanks, and thanks to Shoebox AGAIN
Old Sep 22, 2007 | 11:22 PM
stephenspann27's Avatar
You can check that sensor by putting the car on a scanner and checking the A/C pressure, when my sensor was bad it read 0psi, which disables the a/c clutch. My new sensor only lasted a week for some reason...
Old Sep 23, 2007 | 06:45 PM
Dtimekw's Avatar
Not sure I get what you mean. I scanned the car and it threw a several codes, 66,67 and something about a transducer. I cleared the codes (didn't write them down like an idiot ) and the only one that came back was 67. I check the resistance between all 3 pins before and after the problem and the resistance was the same. What else could cause this? It is getting hot down here in South Florida..............HELP
Old Sep 24, 2007 | 11:29 AM
The scanner I have allows you do view "operational" data. Real time data like RPM, vehicle, speed, O2 stats. I"m also able to view the A/C psi. and when my sensor was bad it read 0psi instead of the 200-250 it should have. The sensor is about $60... You if you had a new one or, a friends you could compare the Ohms across the pins, or slap one in off a buddies car. You won't loose any refridgerant when replacing it, there is a schrader valve
Old Sep 24, 2007 | 11:56 AM
So I just fixed my car. I had enlarged the connectors on the plug that goes into the pressure sensor when I jumped it with the wire. So it wasn't making a good connection on the sensor
Old Sep 24, 2007 | 05:58 PM
Dtimekw's Avatar
Still pulling my hair out. I replaced the sensor, figured it was worth it. No joy. As I scan, I can watch A/C demand turn on when I turn on the A/C and then a second later A/C clutch turns on but no cold air.
When I started the car this afternoon after replacing the sensor, the A/C was ice cold, cycled on and off for about 10 minutes in the garage, figured I fixed it, took it for a test spin and not more than 2 minutes from the house, it quit. It threw a code 67 again. Both fans are on and running. Are there any other sensors that could cause this? I've tried to jumper the relay but no joy, which two do I jumper????
Old Sep 24, 2007 | 09:28 PM
Dtimekw's Avatar
I added a small can of 134A tonight and ran it at idle for over 30 mins with no problem. I put a temp gauge in the vent and got a cold 58 degrees. I will take it for a test drive tomorrow but want to know if anyone else has had this problem?? I don't want to take it to the shop but I am running out of ideas.........
magman
Apr 15, 2016 03:08 AM
WPHIG2
Aug 27, 2015 06:37 AM
MikeWhitener
Aug 2, 2015 06:17 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
