Converting 02 'Bird headlights to H4
Old Sep 19, 2007 | 05:25 PM
Ten_32's Avatar
I know there's a how-to on this out there somewhere, but I've searched and searched to no avail:
I want to switch my 02 Firebird low beams from the sealed beams to H4 bulbs so that I can run Silverstar bulbs. Does anyone know how to modify a sealed beam or where a kit can be purchased for this?
Old Sep 19, 2007 | 10:13 PM
Danny McAdams's Avatar
Email addy is z28@performanceworks1.com, he had an article on the conversion on this site
Old Sep 20, 2007 | 03:20 AM
BlackbirdWS6's Avatar
you can also pick up new housings from rallylights.com . Once you convert your housings, which accept H1 or whatever lamps, all you need is the adapter harness that they also offer. Very simple to do. I replaced my stock housings with Hella free-form housings with H4 style lamps and adapters. Great mod.
-Brian
Old Sep 20, 2007 | 04:11 AM
Ten_32's Avatar
-Brian
Good lord!! $224?!! By the time I buy the Silverstar bulbs, I might as well go with HIDs for $315 from one of the sponsors. Thanks for the info and quick reply, though. I was just hoping to find a cheaper way to go.
Hopefully I can find a way to do this on my own.
Old Oct 11, 2007 | 12:56 AM
Ten_32's Avatar
I was looking at the write-up on this mod on the website listed above and it says to use 9005ST bulbs so that no wiring modification is needed but the author owned an LT1 Camaro. I have an 02 Firebird, does anyone know if this will still be true?
Old Nov 2, 2007 | 07:43 AM
I doubt the same tutorial would apply but I could be wrong. The 98+ birds have an expensive conversion whereas my LT1 conversion is much cheaper for some odd reason. However, going with a quality conversion will pay dividends every time you drive your car at night. Plus, being a little bit more pricey, not a lot of people will be getting them so you will be different than the next guy in a good way.
-Brian
zFrank
Aug 12, 2015 03:46 AM
ricks95TA
Jul 23, 2015 12:59 AM
ricks95TA
Jul 22, 2015 10:15 PM
