hooking up an amp to factory monsoon?
Old Sep 15, 2007 | 01:21 PM
GhostZ28's Avatar
is it possible to hook up an amplifier to my stock cassette monsoon? If it is possible, which one is the remote wire and how do i do the rca connections?
Old Sep 16, 2007 | 01:16 PM
angel71rs's Avatar
might help, from the monsoon sticky on ls1tech:
"You will need a line-level adapter that is available for just a few bucks from any stereo or electronics shop. It will convert the speaker-level output of the head unit to the pre-amp (line-level) input needed by most amps (you can also buy some amps with speaker-level inputs). A common place to mount the amp out of sight is with a mounting board at the back of the car below the hatch lock. There are all kinds of options if you want to show off your amp - check out sites such as subthump.com for some ideas."
If you haven't bought an amp yet, getting one with speaker level inputs would be easiest.
http://www.ls1tech.com/forums/showthread.php?t=612644
As far as the remote, C3 pin 11 is listed as "(convertible) amplifier sensor" in that same sticky, so that might work. If not, just tap any power source that is hot when key is ON or ACC. Remote sense input on amps draw very little current, so no worry about overloading.
Old Sep 20, 2007 | 07:41 AM
midnightnavyz28's Avatar
if you aren't sure how to do this i would honestly buy a new cd player or pay a pro. to do it 4 u..i do this **** 4 a living and u can screw ur self if u dont know what u doin!
HibachiZ28
Nov 6, 2015 12:53 AM
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
TGGodfrey
Aug 17, 2015 08:43 PM
Aug 5, 2015 08:35 AM
tomfric
Parts Wanted
Jul 30, 2015 03:01 PM
