QUICK QUESTION! What type of steering fluid?
Old Sep 14, 2007 | 04:57 AM
flexus's Avatar
I am replacing my rack and pinion assembly along with ends and i want to flush the old fluid and fill it up with new one, just i don't know what type and i couldn't find it anywhere.
I have a '96 v8, 16" rims, SS model.
I don't live in the US so i'll need some kind of universal type of steering fluid to find it here.
Also, how much is needed for a complete refill?
Thanks!
Old Sep 14, 2007 | 06:10 AM
Dave89IROC's Avatar
automatic trans fluid will work if you can't locate P/S fluid
heck, it the US, the only kind of P/S fluid thats easy ti find it universal stuff
Old Sep 14, 2007 | 07:25 AM
flexus's Avatar
Ok then, i'll get some ATF but how much is needed for a complete refill of the system?
Old Sep 14, 2007 | 08:43 AM
n2ceptor's Avatar
Automatic Trans Fluid has detergents in it that wear out seals faster...... I would suggest just power steering fluid only....... JMO
Old Sep 14, 2007 | 04:22 PM
Dave89IROC's Avatar
i never had any problems, hell, ATF has fixed seaping P/S hoses on more then one of my vehicles
and I would say 2 quarts/liters would be enough, if the system is completely empty
what types of P/S fluid are available to you over there?
Old Sep 14, 2007 | 06:24 PM
n2ceptor's Avatar
Carquest power steering fluid (made by Warren Unilube INC)
Vavoline power steering fluid
Pyroil power steering fliud
Old Sep 14, 2007 | 07:21 PM
dangalla's Avatar
yeah and most auto manufacturers recomend atf
Old Sep 14, 2007 | 09:42 PM
Mtrhds94Z's Avatar
Valvoline SynPower is excellent PS fluid..
Old Sep 14, 2007 | 09:50 PM
Dave89IROC's Avatar
guys, he's not in the US, so we are seeing what he does have access to , not what you use
Old Sep 14, 2007 | 10:21 PM
Bayer-Z28's Avatar
I used Valvoline Synthetic... I had a problem w/ boiling my PS fluid when canyon carving.. I flushed the entire system and replaced it w/ that. It should take about a qt to do the entire system. I bled the rack down too..
Old Sep 14, 2007 | 10:29 PM
n2ceptor's Avatar
What country???????
Old Sep 14, 2007 | 10:58 PM
shoebox's Avatar
They do? The GM owner's manual (4th gens) says to use ps fluid.
I guess I would try ATF if I had absolutely no other choice.
Old Sep 14, 2007 | 11:30 PM
Bayer-Z28's Avatar
^ yep.. PS fluid.. I have fluid specs in my stickey in the LSx Room.. Right out of my owners manual..
Old Sep 16, 2007 | 04:23 PM
flexus's Avatar
I've looked up on the internet and at some gas stations what was available, i found that pretty much anyone who makes car oils makes special PS fluids. Apparently PS fluids don't have types, they're universal for any car any system...
I've found 2+2 PS fluid 1/2 quart, about 6-7$.
I'm sure if i look more i'll find other types too. I am thinking of going for some PS fluid imo.
Old Sep 16, 2007 | 04:33 PM
n2ceptor's Avatar
Hondas' and Toyotas' do have their own recommended type... But just about everyone else is universal, unless its an exotic.....
