Sway bar question???
Old Aug 31, 2007 | 05:42 PM
rexcellent's Avatar
Is the 32mm 1LE sway bar any good? I have found one for cheap and I am wondering if it is worth buying or not. I have heard the 35mm are good but I don't know if the 32s are that much worse. Any help would be nice.
Old Aug 31, 2007 | 07:12 PM
AXEMAN's Avatar
When I put mine on with poly end links and bushings it made all the difference in the world. I hear that a 35 front and 21 back will make an even bigger difference.
Old Sep 1, 2007 | 09:43 AM
rexcellent's Avatar
Alright I guess Ill pass on the 32 and save for the 35. Thanks.
Old Sep 2, 2007 | 04:07 AM
karpetcm5's Avatar
strano 35 fronts and 21 solid or 22 hollow rear same thing is a huge difference. I had the 32 1le up front went to the 35 felt a big difference.
Old Sep 2, 2007 | 10:54 AM
Bud M's Avatar
If you can get the 32 cheap, it is an upgrade, but the 35 is even better.
Old Sep 2, 2007 | 11:54 AM
Greed4Speed's Avatar
I agree, it depends on how cheap you can get the 32mm bar. My Camaro came w/the 32mm and just from test driving different cars before I bought it, it was a noticable improvement over cars equipped w/the smaller bar.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
8T8IROC
Mar 26, 2015 09:02 PM
97TA-WS6-Con
Sep 5, 2002 02:26 AM
