Anybody See This Yet?
Old Aug 30, 2007 | 09:20 AM
supr_bikr_99's Avatar
Was lurking around on GM Inside News this morning and came across this article on the possibility of Direct Injection in the next gen V-8. They specifically mention Camaro as well as Impala. I also thought it was awesome that the DIG engine was making MORE power running on E85. It's an interesting read and wanted to share! Here's a link to the entire article on GM Inside News.
http://www.gminsidenews.com/forums/s...ad.php?t=54138
“GM would want to introduce this (DIG) on a high-profile vehicle, such as the new (Chevrolet) Camaro or (rear-wheel-drive) Impala,” Global Insight analyst John Wolkonowicz says...
Old Aug 30, 2007 | 09:45 AM
Primus's Avatar
I'm certainly all for it. How does E85 prices compare to regular unleaded?
Old Aug 30, 2007 | 09:48 AM
km9v's Avatar
Yes:
http://web.camaross.com/forums/showthread.php?t=540531
Old Aug 30, 2007 | 10:11 AM
Angelis83LT's Avatar
depends on where you are by what I have seen and heard. Some places it is about the same as regular, other places about 35 to 40 cents less. never seen it more than 40 cents less though. Most often it is in the 25 cent per gallon less. that what it is here with three e85 refineries within 50 miles.
Old Aug 30, 2007 | 05:25 PM
hyperv6's Avatar
DI is the wave of the future. We may not see it on all the engines at intro but in time it will spread to V8 and V6 applications.
As for E 85 it is more expensive here is Ohio and less efficent so it is not real bargin for us. Yet!
Old Aug 30, 2007 | 07:08 PM
jg95z28's Avatar
FWIW, E85 isn't even available in most of California.
Old Aug 31, 2007 | 06:25 AM
hyperv6's Avatar
Here is a little on DI.
GM Reveals Small-Block V-8 with Direct Injection - wardsauto.com
By Mike Sutton
Aug. 29, 2007
MILFORD, MI – Although General Motors Corp. is dividing its resources to cover all fronts of advanced powertrain development, the future of the auto maker’s foundation OHV small-block V-8 architecture appears secure with the advent of direct-injection gasoline (DIG) technology.
Among the various exhibits of engineering bravado on display at the auto maker’s proving grounds here, including two-mode hybrid-electric drivetrains, ultra-clean turbodiesels and homogeneous charge compression ignition flex-fuel engines, a seemingly untouched Cadillac Escalade stands out.
Emblazoned with giant E85 banners down its flanks, there is little to indicate the industry’s first OHV V-8 with DIG fueling lurks beneath the SUV’s pearl white hood.
The experimental engine is based on GM’s current all-aluminum Gen IV 6.2L V-8 (L92) found in the Escalade, GMC Yukon Denali and Hummer H2. Depending on the application, the powerplant, which sports port fuel injection, variable valve timing (VVT) and dual-cam phasing, is rated between 380-403 hp in stock form.
However, with a little tweaking to accommodate the auto industry’s latest fuel-injection hardware, the prototype V-8 is producing “well north of 450 hp (on gasoline),” says Dave Sczomak, development engineer-GM Powertrain Advanced Engineering.
Running the engine on E85 ethanol allows for even more power to be coaxed from the big V-8, he adds, noting the 85%/15% ethanol/gasoline mix generally carries a race fuel-like 106 octane rating.
Cruising the web of test roads onsite, the Escalade motors along smoothly with a characteristic large-displacement V-8 burble. However, mashing the gas from a standstill produces a wave of power that propels the big truck at a noticeably more rapid pace than the production version.
Along with the substantial increase in horsepower, DIG also contributes to about a 10% increase in low-end torque, Sczomak says. In addition, fuel economy is moderately improved (3-6%), as are cold-start emissions of hydrocarbons.
To accommodate the DIG fueling system, GM redesigned the L92 cylinder heads, rearranging the intake ports to make room for the eight high-pressure injectors that squirt fuel directly into the side of the combustion chamber at 2,250 psi (155 bar).
New dished pistons – similar to a diesel’s – were installed for added clearance of the injectors. They also contribute to a greater compression ratio (11.5:1 vs. 10.5:1), which can be employed because of the high-octane composition of E85 and the knock-reducing cooling effect of introducing fuel directly into the cylinder.
A modified engine controller manages the engine’s operation, while VVT and Active Fuel Management cylinder deactivation contribute to efficiency and refinement.
The development sounds like a no-brainer for improving nearly every aspect of the near-60-year-old small block’s performance.
However, Tom Stephens, group vice president-GM Powertrain and Quality, notes introducing a production DIG small block would “require the next-generation architecture” of the engine, or Gen V.
This primarily is due to the huge volumes of V-8 engines GM produces, Sczomak says, noting a radical change in cylinder-head design, for example, becomes a monumental undertaking when taking into account GM’s annual build of more than 1 million small block V-8s.
Fortunately, timing is on the auto maker’s side. The recent introduction of the ’08 Corvette’s 430-hp LS3 V-8, along with the release later this year of the ’08 Chevrolet Tahoe Hybrid’s 6.0L V-8, represent the last editions of the Gen IV engine family, Stephens says.
All subsequent introductions will be of the Gen V architecture and could have DIG fueling integrated from the ground up, especially considering the refinement of the current test engine’s operation. The greater specific output provided by DIG also would allow for greater engine downsizing, thereby improving fuel economy even further.
“GM would want to introduce this (DIG) on a high-profile vehicle, such as the new (Chevrolet) Camaro or (rear-wheel-drive) Impala,” Global Insight analyst John Wolkonowicz says, referring to the auto maker’s plans for new volume models based on its global RWD platform developed by GM Holden Ltd. in Australia.
The new Camaro, which originally was shown at the 2005 North American International Auto Show in Detroit, is expected to appear later next year as an ’09 model, with the all-new RWD Impala taking form sometime early in the next decade. Revisions for future generations of the Corvette and Chevrolet Silverado/GMC Sierra pickups are expected in the same timeframe, Wolkonowicz says.
By capitalizing on areas of significant improvement that remain untapped in its core engine lineup, while simultaneously amping up the arrival of its new hybrid-electric vehicles, clean diesels and hydrogen fuel cells, GM clearly is betting on an ever-fracturing market for advanced powertrains.
As a result, the iconic grumble of the small-block V-8 appears poised to remain a fixture of the automotive landscape for the foreseeable future.
wards auto.com
Old Aug 31, 2007 | 10:35 AM
Northwest94Z's Avatar
The new CTS runs a 3.6 DI V6 engine. I believe it makes 304 or 306 HP.
Old Aug 31, 2007 | 03:00 PM
hyperv6's Avatar
It has 304 HP and that is only the start.
The 2.0 turbo Ecotec is DI and at 260 HP with more coming.
Old Sep 1, 2007 | 10:02 PM
Dwarf Killer's Avatar
Depends on cost and reliability. They should get that perfected before the just throw it into a high profile car.
Old Sep 2, 2007 | 07:03 AM
hyperv6's Avatar
They did or we would not be seeing it.
The increase of cost is the factor here.
But with the need for Better emissions and better mileage it will make the cost worth the effort.
Look for the DI engines in the more expensive top lone cars at first and in the cheaper base cars later.
This is no differnt to how they gave us Anti locks and Stability Traction Control. The more they mske the cheaper it is.
Old Sep 2, 2007 | 07:01 PM
N Vezzi's Avatar
DI would be good for the car, long term. Especially with gas as expensive as it is.
Old Sep 4, 2007 | 12:16 AM
Yeah see sig. It's kind of funny. My 2007 I4 GXP is as fast as my 94 Z28 (sold) was 13 years ago. Granted it is turbocharged.
