Dual walbro setup
Old Aug 24, 2007 | 08:17 PM
93BlackTA's Avatar
Dual walbro setup
When the second pump kicks in under boost, did you see a big jump in fuel pressure? did you have to make any adjustments in the tune?
Old Aug 24, 2007 | 10:42 PM
FireChicken1995's Avatar
you shouldnt see a jump in fuel pressure b/c the fuel pressure regulator will keep the fuel pressure at 45psi or so unless you have a aftermarket one set higher or if its got a boost reference. Pretty much all you get is more volume. the tune should stay the same unless you have messed with settings to compensate for a lean condition due to not having enough fuel do to too small of a pump.
Old Aug 27, 2007 | 11:31 AM
mzgp5x's Avatar
Currently running a 2 walbro 255lph intank pumps with KB voltage spike on pump #1. My app is a 97ss LT1 383 D1 FI. Both pumps are on all the time with the option to turn off pump #2 by switch. A boost ref regulator returns fuel to the tank via. 3/8 (-6an) line. For WOT, the regulator will spike fuel rail pressure from 43psi to 49psi when manifold pressure is @ 5psi. I used a Dynojet WB O2 unit to dial in the correct afr in WOT PEvs. rpm closed loop mode. It helped alot. The stock fuel system is gone. Mod with -8an fuel feed. Hope this helps. B.
Old Sep 2, 2007 | 10:22 AM
wicked_95z's Avatar
I usually see about a 3psi increase in pressure when I turn the 2nd pump on
generaldave
Sep 25, 2015 06:48 PM
bunker
Aug 21, 2015 10:21 AM
Slayer
Aug 17, 2015 03:55 PM
Catmaigne
Jul 14, 2015 05:17 PM
mrwz28
Jul 8, 2015 09:11 PM
