NX 100-150 shot wet kit-need wideband?
Old Aug 21, 2007 | 10:56 PM
maro z28's Avatar
Do I need or will I be benefitted by a wideband 02 sensor if I get a 100-150shot wet kit? (sorry for the dumb question,btw)
Any suggestions on which ones to go with and where to buy and how much they cost would be appreciated as well. Thanks!
Old Aug 22, 2007 | 08:24 AM
Z-RATED94's Avatar
Why not have a shop check your NA tune, and then they can also set you up with the right jets and timing for the juice too. It's not cheap, but I'd rather be safe then sorry. Do you have a way to retard timing?
Old Aug 22, 2007 | 05:32 PM
Boosted_Z28's Avatar
In my opinion, any accurate way to monitor ones A/F ratio is a benifical thing. It is an great way to "view" what is going on inside your engine. Although you need to know when things aren't right and tune it or have it tuned to correct the condition(s).
Innovate among others make some great products for monitoring engine A/F ratio. Check this site out:
http://www.innovatemotorsports.com/
Old Aug 23, 2007 | 09:34 AM
maro z28's Avatar
What I'm really asking is:will the PCM be able to more accurately calculate the AFR w/ a wideband sensor? This, unfortunatly, is a dd so I run in MAF closed loop.
Old Aug 23, 2007 | 10:54 AM
Ray@NitroDaves's Avatar
A wideband will not change how your PCM make A/F adjustments...it is used for you to monitor how well the PCM is doing its job.
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
