ABS inop problem
Old Aug 20, 2007 | 08:43 PM
christopher_yerkes's Avatar
ABS inop problem
I have been having a problem with the brake system on my 94 camaro. It takes a lot of power to brake the car and sometimes with the pedal all the way to the floor it keeps rolling. The as inop light has also been on when i start the car and when the car is in drive. Any help would be great.
Old Aug 21, 2007 | 06:09 PM
krispy's Avatar
What condition are your brake pads in (how much material left)?
Also, have you bled your brakes recently?
Old Aug 21, 2007 | 10:06 PM
I just replaced the brake pads on each side and checked the calipers and they were fine. I havent bled the lines yet. A couple of places i called said that it may be the sensors in the hubs. Not sure where to turn next
Old Aug 22, 2007 | 01:35 PM
jhthornley's Avatar
my 2 cents
Bleed the brakes... maybe new fluid???
remove and clean the sensor on top of the differential.. (that is what was causing my ABS inop light to come on)
Old Aug 22, 2007 | 10:29 PM
Is the sensor on the outside of the differential.
Old Aug 23, 2007 | 10:48 AM
multicar's Avatar
If no traction control, the sensor is screwed in to the top of the hogs-head....3channel ABS.
If you have traction control, you have a sensor at each brake backing plate....4channel ABS.
hope that helps,
Doug
Old Aug 23, 2007 | 10:55 AM
dangalla's Avatar
how is the brake fluid level in the resivour
sounds like you may have a leak or at least some air in the line somewhere
Old Aug 23, 2007 | 07:22 PM
I have traction control and the light isnt going on so does that mean that the sensors in the hubs are out.
Old Aug 24, 2007 | 06:21 AM
CheshireCat's Avatar
As for the brakes not giving you good stopping power, as said before thoroughly bleed the brakes starting with the ABS module and then working the rear pass side, rear drivers, front pass, and finally front driver.
As for the ABS inop light. It could be the sensors in the hubs, the rear sensors, of the most common cause...
Check the center mounted 3rd brake light... If the bulb burns out, it will trigger the ABS inop light. There are 2 bulbs in the center mounted 3rd brake light.
Old Aug 24, 2007 | 04:35 PM
Ok man i will try that this weekend thanks.
Old Aug 26, 2007 | 07:05 PM
Thanks for the help the ABS INOP light is off but i still have a braking problem. Im going to have the brakes bled by a shop since i heard that you have to have a program tool for the job.
Old Aug 28, 2007 | 03:21 PM
adamc's Avatar
to bleed the brakes? program?
Old Aug 29, 2007 | 10:00 AM
I don't think TCS was available on the 94's. Are you sure you have it? Are you referring to the "LOW TRAC" light?
You can bleed the brakes without the Tech-2. That is only necessary if you have an active ABS code, and the "motors" need to be homed.
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Black Sunshine/ 00SS
Aug 31, 2002 02:26 PM
Aug 24, 2002 03:41 PM
