B&M Cooler Installment Question
Old Aug 15, 2007 | 09:54 PM
htweels86's Avatar
Hi all,
I'm installing B&M's Transmission SuperCooler #70268 for my 4L60E equipped '94 Z28.
My question is does it matter which direction the cooler line fittings are facing when installed? For example if both fittings are facing down will the ATF still be able to flow thru the cooler properly? I would just install it so the fittings are facing towards the passenger side but there's not enough clearance to get the zip-ties thru the cooler holes @ the top & then put the locking tabs on...
Old Aug 16, 2007 | 01:49 AM
smoknta's Avatar
No it does not matter, the fluid is under pressure.
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
thenewkid
Nov 27, 2014 09:41 AM
