Nitrous System Wiring
Old Aug 9, 2007 | 11:10 AM
Ray@NitroDaves's Avatar
This thread should help with basic wiring questions, if any unique diagrams are needed please let me know.
Base single nozzle system
Single stage, FPSS, and MSD window switch
Single stage. purge, our digital window switch, FPSS, and 12v timing retard
Old Aug 9, 2007 | 11:13 AM
Zex and Mallory 685
Single stage, FJO Progressive, FPSS, and TPS activation
Single stage, MSD window switch, FPSS, Trans brake/2 step
Single stage, LS1 Timing Tuner, our window switch
Old Aug 9, 2007 | 11:17 AM
our 4 button switch panel...System, Purge, Heater, and Remote Opener
Old Aug 9, 2007 | 11:41 AM
2000GTP's Avatar
Great diagrams Ray. I noticed LS1tech has a sticky with these kinds of diagrams. Maybe we can get this stickied here too as this does come up quite frequently.
Old Aug 10, 2007 | 05:22 PM
JodyJ's Avatar
Thanks Ray!
Old Aug 11, 2007 | 12:51 AM
reamo04's Avatar
definately agree, sticky!
Old Aug 13, 2007 | 03:14 PM
scarface007's Avatar
what about the single stage with the mallory 685 , fpss,bottle heater ,and purge.
Old Aug 13, 2007 | 05:29 PM
use this one
the violet wire from the 685 will connect to the FPSS and pin 85 on the relay
the yellow wire from the 685 will tap into pin 87
Old Aug 13, 2007 | 05:32 PM
JodyJ's Avatar
Ray, I just got the FJO controller, do you guys carry the solenoid driver module?
Thanks,
Jody J.
Old Aug 14, 2007 | 11:11 AM
Made this on as it should be pretty popular
Heater,
Old Aug 17, 2007 | 01:10 PM
bump
Old Aug 17, 2007 | 01:16 PM
JodyJ's Avatar
Is it possible to make this a sticky?
Ray, is there a way I can get a hi res sent to me of these wirings?
Thanks,
Jody J.
Old Aug 17, 2007 | 06:23 PM
RedTtop6spd's Avatar
Sticky please.
Old Aug 18, 2007 | 12:50 AM
11secgen's Avatar
this saved my *** earlier, a google search didnt help.it turned out that i had a bad relay ,from dyno tune nitrous systems ,ebay, but i was trying to trace the relay wires,and this was exactly what i was looking for.
Old Aug 19, 2007 | 03:32 AM
Juiced91Z's Avatar
Ray, on post #2 on the 3rd diagram with the t-brake single stage, where is the 2 step actually wired into that? i didnt see that anywhere on the diagram
