A/C quit
Old Jul 31, 2007 | 11:53 AM
jhthornley's Avatar
A/C quit
Funny, earlier this month my A/C was working OK, but I thought it could probably use some more freon, so I was doing some research on here.
2 afternoons later, when it was hot as hades (of course) I get in the car to drive home and the A/C won't work...
I get home and check this site for a diagnosis thought process...
1st thing, pull 2 fuses... one in the car and one in the engine compartment... both look ok... Put them back in.
Fire the car up about 1/2 later and bingo, A/C is working... humm????
Went to the car parts place and bought a can of R134 and put it in.
A/C is working great now...
no clue..
Just thought I'd pass my findings on..
JT
Old Jul 31, 2007 | 03:51 PM
n2ceptor's Avatar
You might get a shop to hook up the guages to the low/high side and get a pressure reading.....
If the pressure is low, then the A/C compressor will not turn on or it will be sporadic....
The A/C compressor is controlled by the Clutch Cycling Switch, plus there might be a high/low pressure switch also.....
Improper pressures will lead to damaging components......
magman
Apr 15, 2016 03:08 AM
KYWes
Sep 26, 2015 08:49 AM
greenzee28
Sep 25, 2015 04:29 PM
DelSoto
Sep 19, 2015 05:31 AM
cmsmith
Sep 14, 2015 09:09 PM
