AC Compressor HELP
Old Jul 28, 2007 | 03:09 PM
97 RedSS's Avatar
AC Compressor HELP
Been 3-4yrs since I've had any refrigerant in my AC lines so today(95 degrees+) I had a shop pull a vacuum and fill with fluid..
Problem is we couldn't get the compressor to pull in no matter what. Instead of paying him alot of $$$, I thought I would take it home and troubleshoot on my own...he was thinking since I had the custom program in my PCM it could be turned since I didn't have the AC before...
Anyways, I've done alot of troubleshooting and it looks like everything is working correctly to get the power to the compressor.- I pulled off the connector at the compressor and it's getting 12 V so it should be pulling in correct???
It isn't frozen or anything and I tapped on it with a rubber mallet to see if that would get me anywhere..
Any suggestions..
Thanks
Cody
Old Jul 28, 2007 | 03:17 PM
Stl94LT1's Avatar
Turn the A/C on MAX, jump the A/C relay, and see if the compressor engages.
Old Jul 28, 2007 | 03:42 PM
97 RedSS's Avatar
No go, i've reset the pcm also. if the compressor has voltage it should pull in right?
Old Jul 28, 2007 | 05:20 PM
97 RedSS's Avatar
Running PCMCOMM , its showing .94 V for A/C Pressure...could that be the issue? I tried jumpering the switch(gray wire to red and clutch still did't engage)
My fans do not come on when A/C is turned on also...
Old Jul 29, 2007 | 12:40 AM
Stl94LT1's Avatar
If you jump the A/C relay the compressor will come on no matter the pressure. You may have a bad compressor clutch.
Old Jul 29, 2007 | 11:07 AM
JP95ZM6's Avatar
Yes, sounds like a bad clutch coil. If it does not blow the fuse, then the coil may be open, as opposed to shorted. Measure the resistance across the clutch connector (2 blade connector on compressor). It should show some resistance, but not infinite. I don't remember the spec, but it should be between 1 and 10 ohms.
Old Aug 6, 2007 | 06:48 PM
97 RedSS's Avatar
3.8 ohms here and still not pulling in the clutch...I'll try moving the connector around and cleaning the prongs..
Thanks
Cody
Old Aug 6, 2007 | 07:05 PM
dangalla's Avatar
dont forget about the ground, ohms check from the connector to the negative battery terminal
Old Aug 6, 2007 | 07:43 PM
Heatmaker's Avatar
Advanced Member
If you jump the compressor and it does not come on at all... It's definitely done for.
Old Aug 6, 2007 | 08:55 PM
97 RedSS's Avatar
that's what it's looking like but I'm trying force it to work..prybar method didn't work
Anyone know the going rate for a new one from someone like Dal or Jason??
I called my local dealer and they were wanting 699 for the compressor and 100 for the dryer
Thanks guys
Cody
Old Aug 6, 2007 | 10:19 PM
Heatmaker's Avatar
Advanced Member
I stole mine of ebay
Old Aug 8, 2007 | 08:11 PM
mcRacing's Avatar
try some auto parts stores advance auto has one for my 84 for under 150
2QUIK6
Sep 17, 2016 02:31 PM
Devinfoote87
Feb 12, 2016 03:21 PM
War Engine
Sep 18, 2015 07:28 PM
WPHIG2
Aug 27, 2015 06:37 AM
AtlasXVIII
Aug 24, 2015 11:41 PM
