TPS Voltage
Old Jul 26, 2007 | 08:22 AM
93BlackTA's Avatar
TPS Voltage
when my TPS is @ 0% the voltage is .67V.....when its at 100% the voltage is 4.37V.....shouldn't that be higher at WOT.....what would this cause in regards to fuel delivery at WOT.....seems like i am running lean at higher RPMs and wondering if this has anything to do with it?
Old Jul 26, 2007 | 11:52 AM
96lt4c4's Avatar
No, that is within spec and right where the voltage should be. You have something else going on if you are lean. What injectors are you running?
Old Jul 26, 2007 | 11:54 AM
93BlackTA's Avatar
lucas 42lbs but im seeing 75-80% duty cycle at WOT
Old Jul 26, 2007 | 12:03 PM
96lt4c4's Avatar
You may need to watch your fuel pressure to see if it drops at WOT. I would think that 75-80% duty cycle would be OK as long as the injectors dont go static, 100% DC. Also keep a fresh fuel filter on the car. A friend of mine has a 97 Cobra with 15,000 miles on it, with the factory fuel filter the car would run lean on the dyno changed the filter, fixed the problem.
Old Jul 27, 2007 | 11:58 AM
93BlackTA's Avatar
I haven't seen the duty cycle go past 84% yet so i guess thats a good thing...lol...I also put a new filter in place but still have the trouble.
Old Jul 27, 2007 | 12:00 PM
93BlackTA's Avatar
maybe time for a new pump or 2!!!!
truecontr3
Oct 11, 2015 09:30 AM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
Aug 7, 2015 01:26 PM
